2007-2009 front panels will swap into 2010-2014s
jared999
I saw a thread from 4-5 years ago asking about this and instead of necro'ing a thread that contained errors I am creating a new thread.
The 2010-2014 pull handles on the front panels are crap and fall apart. The 07-09s are much stronger and don't fail nearly as often. This is not to be confused with the interior 'chrome' plastic door handles that open the door.
You can put any 07-09 tahoe/yukon/escalade/suburban front panel into your 2010-2014 tahoe/yukon/escalade. It does not matter which trim level you have*, the swap will work for most of them. They are direct bolt ons - all bolt holes line up, the window switch plugs are the same. There are two things you need to pay attention to.
1. There is one part you need to swap. You must have an 07-09 switch bezel for your 07-09 panel to fit onto your 10-14. Just take your old switch bezel off, 3 torx screws and put an 07-09 bezel on.
*2. If you have heated or cooled seats, make sure the panel you are purchasing has a hole size of about 8.75 inches across the greater lengths. I ran across a panel somewhere that had a much smaller cutout for the chrome handle and there would not be enough space for electrical buttons.
The other thing is, the panel styles changed a bit. The 10-14s have a larger round thing under the arm rest. TBH, I prefer the 07-09 style. That and they don't fall apart like the 10-14s.
The rear panels swap from 07-14 with no bezel change required. Rear suburban panels will NOT swap into tahoe/yukon/escalde vehicles!!
The silver bezel is the 10-14 style. The wood is the 07-09 style. I learned this through first hand experience having to replace a crap 2012 panel for a Tahoe.
here are how the panel styles changed. That big bulbous thing is just more stuff that can break on the backside of the panel. Plus it reduces the amount of leg room you have under the arm rest. If you have big balls like me it's nice having that extra space to open your legs. All joking aside you won't even notice the difference if you only swap one side that failed and I doubt anyone else will notice unless you point it out.
1.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Good stuff, thanks for posting.
J
jared999
It always bugged me that they changed the front door panels for 2010-2014, but GM didn't change the rear doors to match. I am glad I have a 2009 :)
Who knows why the decision was made. The odd thing is the rest of the interior is nearly the same and as you mentioned the rears are the same / unchanged.
petethepug
Michael
SoCal
This is a diamond thread. My buddy has a 13 Silverado that has both front door panels toasted.
Here’s the kicker question … can the Escalade panels be used across other models?
I read a bit more … yes!
mikeyss
Longmont, Colorado.
The Escalade door panel is a little different, the trim where the heated/Ac seat switch is located is different and I read that the cable for the door handle is slightly longer because of it.
petethepug
Michael
SoCal
Gotcha, I’ll dive into it when I get a chance. Sounds interesting.
J
jared999
If your sierra / silverado has a door panel like this, a tahoe/yukon/escalade panel will NOT be a direct swap. The trims won't look right nor line up, you will lose out on one securing bolt and I don't think the master switch can be swapped*. There is also the matter of the cable to open the door. You'll need a longer one.
*Perhaps the master switch won't need to be swapped if the plugs on the tahoe/yukon are the same as the sierra/silverado master swtich, but I am unsure.
Trey Hardy
If your sierra / silverado has a door panel like this, a tahoe/yukon/escalade panel wil NOT fit.
Actually you can convert it over by swapping over the cables on the door handles off a ltz if I’m not mistaken? However without swapping to a ltz dash it lines up funny and the dash swap is a way more tedious project then the Somewhat simple door panel swap
J
jared999
You touched on the main points for sure. It could possibly be converted over.
I don't consider it a swap though, due to the trim not lining up, changing out the cable, the door not looking the same as the rest of the interior and missing one securing bolt in the process.
91RS
GA
No. If the Chevy or GMC has heated and/or ventilated seats, you cannot use Escalade door panels. The Escalade has the seat buttons in the HVAC control head and the opening for the inside door handle is smaller. The driver panel only has the driver 1/2 buttons and the passenger panel has no buttons at all.
Trey Hardy
I used them on my ltz but your correct I swapped my window buttons out so it had the plug for my heated seats and my redneck ass ran the heated seat button behind the triangle trim piece where the mirror bolts on at
So when someone rides and asks how to cut the seats off I just tell em to look behind that cover lol
91RS
GA
Looks like you have an extended cab since it has the indention for the seat belt retractor so you’re going to need the extended cab panel. If you had a crew cab, the panel would be the same as a SUV.
itsbo1313
Louisiana, MO
Bummer. Thanks for the info though. I’ll narrow my search.
petethepug
Michael
SoCal
That’s a really good factoid about the extended cab’s notch on the lower panel.
Velt
So I've swapped my Silverado panels for the Suburban but can't figure out how to wire the switches.
mikez71
Dang 07-09 has a smaller door pocket? But the 10-14 have a big bump blocking the pocket.
GM really doesn't want you to use the door pocket.
a1parrothead
