Ultimate RSE (Rear Seat Entertainment) Setup!
Tahoe14
Central Fl
As WalleyeMikeIII would say "The owner's manual is your friend and download the manual which makes it easier to look things up".
DmaxDenaliXL
I'm super paranoid that as soon as I plug anything into the HDMI ports or USB-C port, that one of my kids will accidentally kick/step on it and damage the built in connector. Has anyone found a bullet proof option for the terrible location of these ports? I have a second row bench so that is where the additional worry comes from.
I'm considering trying some magnetic cables that break away. Anyone tried them? This seems like an easier solution than completely relocating the ports which is what I've been considering.
HDMI
USB-C
navyseal334
Less comprehensive but also less invasive than the suggestion above is get a right angle redirecting HDMI cable to direct your cords downwards ans reduce how far they stick out and serve as targets for kicking.
Not sure if you've already tried this but it reduces my kids' interest in it somewhat.
CMoore711
Rolling through this thread and searched through a few others...
Has anyone figured out a way to add additional screens for the 3rd row passengers that work with the OEM RSE systems? I realize the main reason they're no longer mounted the screens to the roof on the 2021+ models is due to how large the sun roof is now, and perhaps maybe to maintain visibility to the rear for those not optioned with the LCD video rear view mirrors.
I thought to look into a way to add the factory RSE screens mounted on the front seats but instead mount another pair to the back of the 2nd row captain chairs? Then quickly didn't like that idea if you had the 2nd row folded down flat to load/haul something much larger they'd be vulnerable to getting broken that way.
Any options out there?
DmaxDenaliXL
I was actually considering doing both the magnetic adapters with a right angle. In an ideal world, GM would have designed the RSE with a decent OS that had an established app store available. If I could get a few more streaming apps, I wouldn't need a Roku and then wouldn't have to deal with the cord mess.
navyseal334
Even just the majors (Netflix, Prime, Vudu or Movies Anywhere, Hulu) would be a huge value add; no need for an app store or library.
Or even just allow USB playback and the ability to control from the front.
With no data plan, I just put movies on a USB stick but then need to keep a roku in there to access the USB content. Major hassle for something they already had implemented in the 2021 platform (at least USB playback).
Packitup
Ok I've had some time to play around with my USB-C drive and I can confirm my 2021 Yukon Denali has NO issues playing .mkv files. I mostly have .mkv files on my computer anyway, so I loaded one up for the heck of it, tried it on my RSE in the Denali and it played like a champ. I then loaded four other movies for a total of five, all 720p bluray rips, .mkv and again I had no issues. Both screens could see the drive and all five movies in which each screen could play the same movie or two different movies at the same time.
I have a harddrive hooked up to the USB port in the center console. I've tried moving .mkv files I have using MakeMKV (and DvDs) and the system doesn't recognize any files on the drive. I'm not sure if there is a software push that needs to occur. I have a 2021 GMC Yukon with the RES. Is there a way to force the system to re-read the harddive? It seems there is a cache that it works off. I've tried using handbrake and converting the .mkv to .mp4 and the RES doesn't even recognize any of those video's to be able to play them.
MrScrewzloose
SW Florida
Hmm.. that's weird. I'm using a SanDisk 1TB Extreme USB-C, and I've loaded it with almost 100 or so movies in both .mp4 and .mkv format. I did, however, need to reformat the flash drive as it came formated with ExFAT which my 2021 Suburban did not regonize, wouldn't mount at all. FAT will not work with large file size (e.g 4GB+) so I went with NTFS. Once formatted, I created a couple folders (e.g. Kids, Action) then transferred the movies. I'm using the USB-C in the center console to keep the drive out of the way and avoid getting it kicked by the kids when coming in/out.
No issues since.
Packitup
No issues since.
I'm using an old seagate free agent go that's 500 GB. It is formatted as NTFS. I do see on the rear screen that media indexing is occurring but the progress bar seems to be stuck half way through. Maybe a quicker reading external drive would help this progress? I actually have a SanDisk 2 TB extreme USB-C but it's utilized on another device. Is there a way to refresh the media indexing?
MrScrewzloose
SW Florida
Is the older Seagate a HDD spinner using USB-A? If so it may be adding to the slowness of the indexing that the system is doing. I've never seen an indexing notification on either my front display or the rears. I do, sometimes, need to unplug and replug the flash drive after starting the truck, sometime the system seems to flake out on mounting the flash drive.
If you have a USB3 thumb drive laying around, with a USB-A to USB-C adapter (I havent tried using only the USB-A up front as a source but it may work), you could toss a couple .mp4/.mkv and determine if 1) its an issue with the other drive or 2) an issue with the movie formatting or formatting of the drive. If it works, go with another Extreme.
Packitup
Yes, the older Seagate HDD is spinning using USB-A. I have a newer Seagate HDD with USB 3.0 and a USB-A to USB-C adapter so I can try both ports. In the process of formatting to NTFS and moving some .mkv over. Will update.
Packitup
Got the new Seagate HDD with USB 3.0 formatted with NTFS, and USB to USB-C adapter. Moved over a couple .mkv movies. Hooked the HDD to center console USB-c port and the videos are showing up and selectable. Tried a few and they would never play. Then selected a few more until one of the .mkv videos did play, success. Now, not sure why the one played while other did not. I wonder if video bitrate and what the HDD can handle is the difference? Need to figure out what's different between the one .mkv video and the others.
BrianM3CX
We had the factor RSE in our last 2019 Tahoe, but when we got our new 2023 Tahoe I knew I wanted to do a custom/portable iPad setup that allows full app access and portability between vehicles.
2 Apple iPad Airs 10.9 size
Lamicall Car Tablet from amazon
Two USB C black cables for charging ran through bottom of seat
Two Beats Wireless headphones with W1 chip
This setup can be run off the Vehicle Data package or using our iPhone hotspots
For front screen I used Carlinkit AI Android Box 8gb ram/128gb storage this allows plug in/play and downloading apps from Google Play Store for streaming entertainment. Front screen does use the built in vehicle speakers/data connection, and power source. (There is a slight audio/video lip sync from the Carlinkit AI Android box, but maybe future firmware update will resolve. Not a big concern as its usually used to watch sports on long weekend trips with kids travel teams)
This setup allows all three screens to be watching something totally different. Portability between two vehicles and all for less than $600-$1000, depending on iPad size/discount/sale you catch on amazon at the right time of year.
Overall family loves the setup.
GM really needs to open up the Google play store in the new Android/Tahoe stock headunit for the 000's of apps instead of using a Carlinkit AI Android Box as a work around. This Carlinkit AI Android box uses the wired Apple Car Play connection to run in three ways Apple Car play, Android Auto, or Android 12 tablet/phone mode for full customization.
matai
I just read through this whole thread.
Does anybody know the actual tech specs for the USB drive and movie files?
Some of my movies work and some don't, can't seem to figure out why.
Thanks
High_Country
I have a 2023 Tahoe with the original RSE. Unfortunately it looks like it is the system with most of the funktions switched off by Chevrolet. Great... I can only choose beetween two sources: HDMI 1 and HDMI 2. That is all. No USB! No HULU. So what can I do to use it. Can I connect a hard disk via HDMI. My hard disc has only a USB cable. Are there adapters?
What can I do? I am from Europe, here is ONSTAR not available. So I have only my Android Samsung smartphone with "not too much" mobile data...
badreau
Alberta, Canada
I would try getting a streaming device such as an Nvidia Shield, which you can then plug your USB hard drive into. The Shield will connect to HDMI 1 or 2, and play the movies from the USB drive.
High_Country
I go with a very simple solution at the moment. I use a USB C to HDMI cable for my Samsung phone. It is working quite well.
So my kid can watch downloaded videos on the rear entertainment screens now.
As I can download the videos at home, there is no need to use mobile data for the entertainment.
BadDaddy2003
