2009 Yukon 2500 LY6 Dropped Valve seat
Shackman7878
San Bernardino
2009 Yukon XL 2500 186k miles Ex fire chief command vehicle
Was getting a Misfire code cylinder 8, and rich code bank 2. Put a new Spark plug and Ac Delco Injector Cylinder 8 and swapped the Lead and coil to different cylinders cleared the codes and drove it 50 miles then the code came back but what I thought was a Lifter tick (Not DOD). After taking the Valve covers off and running the truck and listening with a stethoscope noticed the rocker on cylinder 8 intake side was crunchy sounding. So I made the choice to pull the Heads and glad I did. Checked the piston did not go very deep and did not bend the connecting rod when I ran the piston all the way up. Last 2 photos are from the machine shop and the guy did an amazing Job. Will post more photos Later in the week due to the snow storm coming my way.
Shackman7878
Shackman7878
San Bernardino
Added more photos.
Geotrash
Dave
Richmond, VA
Fantastic that it didn't do more damage! Those clean cylinder heads sure are pretty.
mikeyss
Longmont, Colorado.
The same thing happened to me about 2 years ago, except the seat broke in half and landed on the piston and shattered it. What head casting you have?
Shackman7878
Shackman7878
San Bernardino
Installed the lifters and guides, head gaskets and heads bolts are snugged down for now. Weather allows will do the cylinder head torque sequence tomorrow.
Shackman7878
Shackman7878
San Bernardino
Truck is up and running.
Shackman7878
Shackman7878
San Bernardino
Also did the trunnion upgrade kit, One had square and powder bearings, and 2 fell out with little to no pressure. Used my 1950 Arbor press.
Shackman7878
Shackman7878
San Bernardino
Lightning never strikes the same place twice..... my friends 2014 Caprice 6.0 L77, What we though was a Bad DOD lifter turned into a nightmare this engine was rebuild under Warranty at a Chevy dealership 5 years ago. The head bolts you can take off with one hand and a breaker bar. So the Yukon was cylinder #8 Caprice was #7
Dh1280
