Backup/360° Camera Issue
CarlsbadChris
Carlsbad, CA
Picked up a ‘23 Z71 about a month ago and having intermittent issues with the backup/360° camera where it’s not operational, maybe happening once every few days. I’ve turned off the ignition and restarted it but that doesn’t fix it. After sitting for maybe 20-30 minutes then it works. Anyone else having this issue? I know the dealer will fix it under warranty but would rather not be without a car for a day if there’s an easy reset/fix.
SunnyDarling
Did you get this resolved? I have the same exact issue. 2023 Z71 with 200 miles on it and it has done this to me numerous times.
Murillohnadia06
I have the same issue with my RST.
Did you get it solved? Or took it to the dealer?
CtrlAltDel23
2023 Yukon w the exact issue. I’ll repost the fix once I figure this out.
penncage
2022 Yukon XL with ~15k mi, same issue - cameras crapped out a couple of days ago. I have an appointment with the dealer tomorrow. Mentioned the TSB, they were aware of it but surprised my 360 cameras were also not working.
I will update on the resolution.
Larsonxjs
Did you ever find a fix for this?
Nope! With the lock/unlock folding mirror option on. The only explanation I can come up with is that on mornings with heavy dew the camera has a bad connection until dry.
ajdahl8660
