21 Tahoe high country grill black out
Nima
Hello
I am trying to paint or vinyl over the chrome parts of the 21 Tahoe front grill.
I have tried different sprays and they all peel off after a month. I haven’t tried the vinyl but I think that’s not an option either as it is not easy to do.
Does anyone know an aftermarket grill or a good solution?
Ideally I like to keep the gold parts and only delete the silver parts.
Please keep the answers only related to the front grill.
Thanks
DuraYuk
Wrap it. That way when you get tired of it you can remove it. A WRAP shop probably won't charge you much to do it.
N
Nima
But do you think it is possible to wrap it ?
Considering all the corners ?
Stbentoak
Take it to a body shop and have it professionally painted?
Yes, that's what they did with mine. Proper prep, and maybe some lite blasting for adherence? Don't know, but mine has stayed great for over 2 years now, so someone knows how to do it right...
N
Nima
Seems like blasting and paint over is the only option so far.
BlaineBug
Clown World
Vinyl may actually be more durable, can be reversed in the future, and more easily repaired. I've heard about "self healing" vinyl wraps too.
R32driver
Its strange there isn’t a black offering from Chevy like there is with the gmc grill. My wrap guy basically said no to wrapping the grill on our slt so I bought the factory black one from gm and it’s great
66 Galaxie
A wonder if OP has a coating on the grill like spray ceramic or something that is causing the peeling issues.
No idea what sprays coatings have been tried but I’ve had grills last for 4+ years with plastic dip. The prep is critical and a good wiping down with Isopropyl Alcohol assures a good clean surface for it to adhere too. Without a truelly clean surface it will peal prematurely.
As soon as it’s warm enough I’m planning to pull my grill and spray it with black hyper dip.
GoNoGo
Elberton, GA
I vote for OP trading in his black Tahoe for one in Silver, grill problem solved !!
CASTLEDFW15
North TX
R332…….for 2030 There is a Black option Grille for NON Z71/RST Models.
I am not sure of Dealer price but I believe $800 ish if Factory Ordered.
The grille is flat black and instead of the blacked out logo it has Chevrolet stamped across the section where the main accent strip would normally be.
Go to Tahoe Build and Price section to at least get idea of the look.
N
Nima
The Chevy grill you are talking about is not for height country and front camera
ProfeZZor X
High Country
If you're committed to that "blacked out" look for as long as you own it, you might as well paint it. Vinyl is only temporary and can be damaged over time just washing it.
sick1166
12,000 miles vinyl wrap
Drewphil
