Dome/Courtesy Lights
SgtPreston
The dome lights in my '94 Yukon worked at one time but quit some time ago - I think they are linked by a common ground wire but I can't find where the wire runs to see if there is a break. The under dash courtesy lights work fine. Any help would be appreciated.
Hoesgottaeat2
Western NY
In which ways have you determined that they are not working?
By opening the doors?
By using the dimmer switch?
S
SgtPreston
Tried both and also opened tailgate . Have checked bulbs also and have 12V but no ground - aren't all the courtesy lights on common ground?
I'm trying to find the wire for the dome lights without tearing the headliner out.
Hoesgottaeat2
Western NY
I haven't looked personally at this but is there any way you can try running a jumper from the bulb socket to a known good ground? Just to verify it is indeed a bad ground or not?
YukonGTmaster
2 Door w/ Barn Doors Club
I had issues with my dome lights. It ended up being an unserviceable "Override" button at the headlight switch assembly.
east302
Mississippi
From the 94 manual. The PDF set can be downloaded here:
S
SgtPreston
Thanks, I'm not sure these apply as my 94 Yukon 2 dr. doesn't have an o/h console but I'll go through the other Adobe files you provided - it seems like I need the wiring diagram for the O/H lights and a cutaway view of the wiring location in the roof, possibly from a shop manual?
S
SgtPreston
The switches provide the ground.
Which switches are you referring to that provide the ground - headlight, door jamb, tailgate . . .? I thought the various lights were linked with a common ground wire run to the various switches. When the door was opened, the jamb switch closed the ground and the lights came on - correct?
east302
Mississippi
Yes, they’re grounded to G202 when a door (jamb switch) is opened.
The white wire on the door jamb connector should be hot at all times, so I’d start there. Jumping the white to black should check the integrity of the ground as well. I’m not sure where the convenience center is on a TBI, but on the 96+ it’s at the interior firewall by the parking brake.
Does the cigarette lighter work? It’s on the same circuit. The circuit’s 25A fuse is good and you have power to it?
S
SgtPreston
Yes, fuse block is on the interior firewall by the parking brake - I didn't think about the cigarette lighter so that's something else to check tomorrow - thanks for all the help.
Eman85
That's right the switch provides the ground for the dome/courtesy lights. All of the switches that control those lights provide the ground to complete the circuit including the keyless remote module.
briannorris
