2007 tahoe
Pandadon
Long story short on my Tahoe only the driver window works from the driver side and nothing else works I’ve cleaned old switch didn’t work replaced the switch didn’t work there’s no cuts in the door harness replaced fuses but if you go to the passenger side the passenger window works and back windows don’t work but don’t want to buy anything yet if the window lock is on but i don’t know because the only thing that works is just the driver window…… can anyone help
Fubar0715
Scott
Southern New Hampshire
Welcome to the forum from New Hampshire - can you provide details about your Tahoe...ie, year, trim, mileage, pics.....If the drivers side switch is bad, it may need to be programed to the truck via bi-directional scanner (Tech2). I am sure someone here smarter than me can chime in to confirm as well as additional troubleshooting. If you happen to have a fleet/service truck such as a PPV (police 2wd) or SSV (police or govt 4wd) - locks and windows may have been disabled.
P
Pandadon
Thanks and it’s a 2007 LT with about 98000 miles and no it’s not a ppv and I will look to see if someone out here in Hawaii has one
without a tech2 your going to have to do more hands on testing.
pull the rear door panels off and a get a jumper wire and apply 12v to the window motor and verify the motors work is one place to start.
Welcome to the Forum from NH.
You are already receiving sage advice from the knowledgeable folks on this Forum, and other members will chime in.
CKendrick
