Replacement Seat Foam?
Marshall2002
Hi all. I'm finally breaking down and getting new front seat covers for my 2002 Yukon Denali. The passenger seat cushion is in decent shape, but the drivers is pretty flat. I've tried to find replacement foam with no luck. I believe the GM part number is 88939304, but it was discontinued a long time ago. It seems like the aftermarket has newer models 2003 and up. Does anyone know if these can be made to work or any other ideas? I've seen videos about steaming the foam to restore, but I'm skeptical. Any help would be appreciated.
nonickatall
Germany
Watch this,
there is a company called Seat Shop.....
That is the Homepage
Watch this,
The Seat Shop doesn't stock passenger seat cushions for this.
Blackcar
This company in link sells foam for your vehicle.
M
Marshall2002
I only see 03’ Denali and above. Did I miss it?
They sure don't list a seat foam cushion for the '02.
Onlyone
New Mexico
Hard to believe on one sells this for a 02’. I guess I’ll have to patch the old one together.
How bad is the pad? Is it breaking apart or just saggy. If the latter, just take it out, steam the whole pad and let it dry completely. It will bring it right back to life.
M
Marshall2002
There’s a small chunk missing. I may be able to patch it.
Onlyone
New Mexico
If you have any foam around you can steam what you have and use some 3m spray adhesive and cut and mold the replacement to shape. Or take some from the bottom, if it’s just a small piece.
Durobans
