Brake Light Switch Harness
2Seven
Wylie, TX
My 2011 LT has an issue with the brake lights staying on. I thought it was the brake light switch down on the pedal. Turns out one of the small wires that plugs in to the switch has come loose. I believe it is the purple wire.
What is the best way to fix this? Should I just order a new plug and splice it in?
Thanks!
wjburken
Eastern Iowa
Thanks!
Might take it to a local mechanic and see if they can extract the connector for that wire from the plug and recrimp it. I have a set of extraction picks for just that reason. Otherwise, splicing in a new plug might be your next best option.
2Seven
2Seven
Wylie, TX
Thanks!
I see that Rock Auto has the whole harness with connectors for about $50. May see if I can get it patched up first and then go that route.
WITCH1975
