Brake fluid leak while replacing motor mount
22h0ffers
I was replacing the passenger side motor mount today in my new to us 07 yukon XL (which will replace our 07 Yukon) when brake fluid decided to rain on my face. (And an trip to the clinic cause I somehow got metal embedded in the inside of my eyelid, but I digress.) it only leaked when jacking up on the motor and the leak came from two hoses up by where you would grab the dipsticks and I went to bleed the brakes when done and im getting so much air. I need more fluid now to try again, it’s definitely an excessive amount of air. My question is why did those lines start leaking and do I replace them or can I repair them? Also I can’t find them on the internet. And also, there has to be air leaking back into the system from there right? Again they don’t leak any other time. Usually I’m pretty ok with vehicles but today has been something else. I’m sorry for the long ramble, I’m tired a bit delusional. Thank you for any responses. It’s that snap together plastic to hard line. If you look close enough you can see a drop.
St. Louis
Those aren't brake lines, those are coolant lines for the rear heater. They each attach to "T" right there on the firewall that also attaches to the heater core and those 2 rubber coolant hoses that run towards the front of the motor.
Multnomah Falls
Military
Welcome to the forum.
What @gooffeyguy said. The mount was bad enough that the lines/hoses got rubbed thru and are partially blocked when engine is settled. You likely induced air in to the brake system but unsure on some of your description. How did you determine that it was brake fluid. That leak(s) cannot be brake fluid or you would not be able to drive the rig and stop it.
Charlie207
LFOD, New Hampshire
Do you happen to have a schematic of the rear heater coolant lines handy?
St. Louis
No I don't, but the lines run along the passenger side under the vehicle and enter just behind the rear wheel well. the same spot where condensate drips when the rear AC is on. A couple members on here have replaced or repaired these so I know I've seen posts with pics, but can't remember who
donjetman
what is pictured are coolant lines. There are 2 plastic heater hose T-fitting there that almost always leak/break with age. I installed 2 gruvenparts.com aluminum replacements:
If you replace the Tees with similar parts, do NOT use a Dorman replacement Tee. Get OEM Tees (if not the Gruven Tee above).
Charlie207
LFOD, New Hampshire
Dang... just the aluminum piece is $95 each.
I can see mine aren't leaking or broken when I stick my head in there with a flashlight.
Multnomah Falls
Military
@22h0ffers, I am a little worried about how you mixed up the brake fluid with coolant and then complaining about air in the brake system. Are you going to respond back to the comments?
petethepug
Michael
SoCal
Purchase the heater coolant tees or factory replacement hoses for the truck now. When they go they’re nowhere to be found except the dealer who’s happy to sell them to you for hundreds. A broken T will drain the motor of coolant in 15-30 seconds forcing you to shut down the motor. That means no power brake, no power steering and a windshield full of steam. If you run the motor until you’re off the freeway, good bye engine.
Keep the T’s, clamps and hoses in the spare tire cavity or in the storage compartment at the left rear of the truck. When it does happen you’ll be back on the road quickly or have everything to do the job on your time & terms. My Indi shop charged $4h to replace both because I had to get outta there. Dealer parts were his only option when I was towed in.
Off Road Pedia
