Gm Brembo upgrade added...sluggish acceleration and much lower mpg.
Chad G 1979
If your ebrake is dragging that could be the cause of the issue. It is possible that it had gotten out of whack when they did the brake change. Hopefully the driving you've done hasnt done much wear on the ebrake system, but if so, then the dealer who did the work can fix that as well. For free ofcourse if they caused the damage/issue to start with.
DuraYuk
B.S. i added Baer erradispeed brakes to all 4 corners of mine those are way more than a lb extra each, did not change even a fraction of mpg, neither does adding 500+ lbs of people and gear. what does change it? pushing the big pedal.
Its not BS it's physics lol. Weight needs more energy to move. It's really that simple.
Rotational mass is a huge deal. Its one of the most 'felt' things there is. Why do you think sports car have such light wheels?
It absolutely does make a difference. Still it's hard to diagnose from the internet. If the brakes are dragging they will get hot. Piping hot if it's dragging as much as he says they are. You could feel the heat with your hand or a infared thermometer.
Be interesting to see what it actually ends up being.
yes it will, but it won't be the brakes
I bet it's the big pedal, my wife can jump in mine and be getting 2-3 mpg more than me and it's not the weight, it's the way she drives versus how I drive
I bet the dealer won't find any issue either if the OP even bothers to ever follow up
these aren't F! car's with carbon fiber parts, they can tow and haul thousands of pounds and the mpg is directly affected by how you drive in fact it's the biggest factor more than anything else. I can make my 12 get 7.5 or 14 on purpose and I can make my 18 silverado get 7.5 or 25 (it's much more efficient when coaxed, my best on it is 32mpg).
if I am wrong so be it, but the wheels spun free according to the dealer and nobody else has reported having lost mpg from a brake upgrade.
If you guys think adding even a hundred extra pounds in brakes will affect your mpg by 6-8 mpg you’re delusional. Otherwise nobody would be putting BBK kits on. And then add the extra 100 lbs from running big rims and now you’re getting what, 12mpg less because you’re ballin on 26’s with big brakes? Come on man you’re killin me.
WalleyeMikeIII
Sunny and Snowy Minnesota
I’d check the tire pressure! Much more likely to affect the economy than new rotors.
The physics of the brake weight requiring more power doesn’t hold for me, because once you get the additional mass spinning, the added angular momentum would tend to keep you moving (vs reduce your economy). Think about it, let’s say you added 50lbs per wheel; that’s 200lbs…same as a passenger getting in with you. Do you see that much Econ redux when your buddy comes along fishing??
WalleyeMikeIII
NVM, I see above he adjusted that. E-brake or stuck caliper…gotta be; but then would see heat rise I would think…
B-train
I do recall some guys complaining about some sort of brake upgrade and it ended up being stuck/sticky calipers. I don't know the post it was in though.
As stated above, basic driving with before, during, and after temps at the hat section (dull area) of the rotors should tell you what you need to know. If suspecting the e-brake, hit the splash shield by the axle after a drive while using little to no brakes and see if it's warm or hot.
Have you tried applying the parking brake to see if it operates correctly? Does it stop the truck? Does it fully engage and disengage? Easy enough to test in a parking lot or back road.
Go for a drive and then jack up each axle immediately when home and spin tires by hand. Listen for noises and see how much force it takes. You could also do a before test with everything cold and see how it feels. None of these things wi be "quantitative " but they can help move in a direction of correction.
Process of elimination......
Thrust
ICT
Look at the Brembo retention springs and guide pins. Did the technician install the spring correctly? Are any of the pins bent, causing the brake to drag?
If you really do have a dragging brake pad you should be able to feel the heat by touching the wheel after a short drive, or drive enough to eventually smell the piston boots (hot rubber).
DuraYuk
It's basic physics. Heres a quick simple read to help you over come your lack of understanding.
https://www.linkedin.com/pulse/what...orted,you're considering making modifications.
Big brakes will negatively affect mpg. OP is having a drastic reduction which could be a combination of factors. But to dismiss the rotational mass all together is short sighted.
DuraYuk
Can you please read this: https://www.linkedin.com/pulse/what...orted,you're considering making modifications.
If OP would respond back we may get a better idea of what's happening. Probably a combination of things.
WalleyeMikeIII
steiny93
https://www.linkedin.com/pulse/what-sprung-unsprung-weight-nikhil-jagdale#:~:text=Sprung weight includes anything supported,you're considering making modifications.
The point is that the difference in the weight is small, IE it isn't enough to cause this significant (6-8mpg) of an impact of mileage to occur.
Many of us know this as we have had these same vehicles with both brake kits on them and our mileage wasn't impacted to this degree. Adding the GMC Brembo kit will not impact mileage by 6-8mpg because of the weight difference.
Additionally the weight difference of this kit is less then the typical weight difference when folks change tires.
T
Tahoered
Hey Guys. Just checking up on the responses and appreciate all of the info being exchanged here. I truly do. Appointment updated for this coming Monday. I want to get there early and have an experienced tech for a thorough test drive. I understand the weight debate...in younger years I seemed to have always installed larger rims which were always heavier than stock, however, this is significantly different. I haven't towed anything with the Taboe yet but I've driven miles with the cabin full of luggage and family and it does not compare to this. I mean, truthfully, you cant even feel the difference in dryiving dynamics from when empty versus driving with 7 or 8 people with luggage in this Tahoe. It just effortlessly gets moving. I am stumped that I am not getting any clear indication of heat coming from any of the rotors or a scent. I wish that were the case. Mind you, the weight added on the vehicle I owned when younger were simple sedans with hp ratings of 190 (95 Maxima) to 250 (08 Maxima). We are now talking about a 6.2L 420 hp engine. It's somewhat hard to believe the rotors and calipers would make that much of a difference. My rear drivers side rotor is showing grooves all around. I've only placed roughly 120 miles since getting these things installed. Other 3 rotors look fine. As reference, this gives me the exact feel one would get if driving a car and the hand brake was lifted. Extra pressure on gas pedal to get moving. Heavier or more weighted steering. Even cruising (letting go of gas pedal) clearly slows down faster than before. I'll be sure to update the chat Monday evening. Really appreciate each and every one of you. Thanks guys.
I said by 6-8 mpg, it’s not happening. No need to be rude. I understand you think you’re smart. These vehicles weigh so much that the slight bit of added rotational mass ( rotors) isn’t going to amount to anything that will affect mpg except slightly, probably not even enough to notice. The slanty pedal will, as noted by other sensible members here. And you’re not really adding anything noticeable in unsprung weight ( calipers) because there’s what, maybe 10 lbs difference? That’s like throwing a few tools in the back. If you still think either of these changes are going to make more than .5 mpg difference in a 5500 lb vehicle with 300 hp you’re out of your mind. Your common sense is missing. This isn’t a race car where every pound counts. We aren’t talking about seconds in a quarter mile. We aren’t dealing with a tiny car that gets 45 mpg.
66 Galaxie
Based on your description of rotor condition the left rear sounds like the problem. Could be parking brake, sticking pistons in caliper or a brake line that was “kinked” during installation so it delays the release of brake fluid pressure which will cause temporary dragging of the caliper. After sitting for enough time the caliper will release until the next time you use the brakes then it will cause a temporary dragging brake again.
DuraYuk
No one is being rude. We are talking about something that can lead to mpg decrease. You have missed the point completely. The link was for you to understand. Weight does make a big difference doesn't matter how big or small the vehicle is. Sounds like his e brake is dragging. Either way we are here to help OP and throwing out sane logic won't help him.
I think it’s you who have missed the point completely. I stated adding a BBK to one of these heavy SUV’s won’t affect your gas mileage enough to notice, certainly not like the OP questioned in his original post. In case you missed it, in his first post as well as in post #16 he’s considering going back to his original brakes because he’s thinking the added weight of this kit has not only decreased his mpg from 18-19 to 12 but he’s even running his tires at 42psi in order to decrease his rolling resistance. And not only is the truck down 6-7 mpg but in his words it feels like he’s pulling a trailer. I’m trying to let him know that adding a BBK to these isn't going to do that. It has to be something else. And I have added Wilwood 16” front/ 14” rear kits on both my 02 supercharged/ cammed Yukon Denali as well as my 08 bagged Silverado with a cammed 4.8 and on neither one did I see any noticeable change in my mileage. Not even 1 mpg, so I might understand more than you think. There are others here who have added BBK’s and none have seen a drop in mileage. I’m done with this little game of I’m right, you’re wrong shit. I’m also trying to help the op, with my actual real world experience. It’s you who aren’t helping with the talk of rotational mass and unsprung weight bs. Show me an instance of a full size GM SUV that has seen a decrease in their mileague from installing a BBK. Actually, no don’t show me at all. Show the OP. Otherwise you’re just blowing smoke up someones ass.
it's just not going to happen with these vehicles. period you can throw math at it all day. meanwhile I can load it up with a 1000lbs of metal and get the same mpg i did empty. it wont handle the same but it will get basically the same mpg on level ground provided you go easy on the pedal.
DuraYuk
No one is blowing smoke. I showed you the link that goes in detail what rotational mass can do. It may not be a result of his total 8mpg decrease but it is no doubt attributing to it. Especially if he is pressing the gas more to overcome the heavier feel. Im willing to bet the truck feels 'heavier' to him and he is using the gas to compensate.
Rotational mass increase can make a vehicle feel very labored. Some less sensitive may not feel it. But many people will.
It could be a dragging brake but he mentions no heat. A single caliper dragging will also cause a pull. What's the likelie hood of a pair dragging ? Probably pretty slim. So next up would be a e brake dragging. Again he says no heat. So that may or may not be it. He doesn't mention any pulling so that rules out a single corner.
The one fact we do have is that he put giant brakes on his suv and complains that it is labored and struggling and low mpg.
To rule out what im saying as 'smoke' is ignorant.
DuraYuk
Yes, sprung vs unsprung weight. Rotational vs static. https://www.linkedin.com/pulse/what...orted,you're considering making modifications
It will be interesting to see what it ends up being. Hopefully he replies back with a quick fix.
JasonW4141
