drewtx154
Good evening all! I have a 2002 Tahoe 5.3 2wd that I just got back into acceptable running quality the day before Thanksgiving. Took me a while but I got it done. Before hand I had Service engine soon light on and bought a cheap code reader and it showed low voltage to knock sensors bank 1 & 2 along with a cylinder 8 misfire code about 2 weeks later.... Started running super rough so I parked it and started researching and gathering all parts I needed. I ended up getting both knock sensors, along with harness, new valley cover gasket, intake manifold gasket, valve cover gaskets, new oil pressure sensor, new heater hose connectors (cuz one of them was leaking into the ignition coil underneath it and a few other small things. Started working on it after I got out of work on the weekdays and on the weekends. Took me about a week and a half cuz I'm a single dad, and I'm not a mechanic but I'm also not an idiot and can learn when applying myself. Anyway all was good and during the time of working on vehicle I read about the oil consumption issue and saw how it gets into intake man, and the like. I order a new fixed office PCV hose cuz I have the rattle variety and was pretty dirty with oil and thought would be a good idea to change that as well. So while waiting for hose cuz that took the longest to get I fixed everything and everything turned out great, vehicle was running strong and everything seemed well. I got the new PCV hose in Friday and I got around to changing it last night and as I was doing that I went ahead and rerouted my throttle cables cuz they were running underneath my engine wire harness and that was making the harness sit up a little high to have my top engine cover installed a little crooked. Also the new PCV hose of course was a nice tight seal coming from the intake, the old was had a little crack on that end and was a lot easier to remove/install. Anyway I did that and closed the hood and went to bed. This afternoon I went for a trip to the local Wally world and upon starting my Tahoe it was idling over 2000 rpm and not at all coming down. Thinking it just needed to break in the new PCV hose just installed I put it into reverse to leave and it shifted hard and made a huge thump. Enough for my 6 year old to say "dad what was that?" So I put it back into park and shut it down. I went ahead and put my old PCV hose back on cuz all was good before I changed that and messed with the throttle cables, but now it's still idling high. Not as high as when I had the new PCV hose but it will not come down under 1000 rpm and is still shifting hard into reverse and when I put it in park the roma creep back up close to 2000... I'm gonna go out there and mess with the throttle cables again and see if maybe I set the adjustment screw too tight because I failed to mention that last night I did adjust it from it's original position but I'm kinda freaked out now cuz I just got it back into good shape and I regret messing with that hose last night and should of just kept well alone cuz all was good in my world.... Yes I have other issues to tend to on the Tahoe but doin what I did last night was not at all a priority until I made it one and I need my vehicle as it's my only one. So any advice, knowledge, clues, etc is super welcomed and encouraged and very much appreciated... If anyone needs more info or pics or whatever please don't hesitate to ask cuz with every notification I get on my phone I will be checking it promptly cuz I just want to get it back to good running quality like I had it... Thank you and God bless!!
