Power Stop Rotors any good ?
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
steiny93
Comparing, Power Stop and Brembo; went through swaps with both in the last year.
So... I did a full brake job on the kids Grand Cherokee, did Power Stop all the way around, rotors, pads, everything. They are great on the Jeep, very happy, they have about 15k miles on them now.
On my Ram 1500 a pad stuck in the rear; so new rotors / pads, went with Brembo (not the calipers as it already had the larger calipers, just the rotors / pads went to Brembo).
All in all,
For the money the Power Stop's are great. I would put them as good if not slightly better then OEM for stopping, squeaking, dust, etc. Her Jeep is a Limited so it has the big Jeep brakes already, went with the top line Power Stop for the Jeep.
The Brembo's are just at another level, they are more money, but they are larger and out stop OEM by a fair margin. No squeak, no dust and they are very useable when cold (for comparison the vette's Brembo's are unfun when cold), definitely would do again on the Ram.
89Suburban
SE PA
What happened on the back side?
pretty sure he had a stuck caliper, nothing inherent to the rotor would cause that.
Yes. However I replaced all the calipers a year ago, and now I have a rear rotor taking a crap in the same fashion. Just sharing my experience, not trying to be a negative Nancy.
rotor isn't going to make the caliper stick, I have had 2 new sets of gmt900 calipers go bad back to back they don't seem to hold up as well as the gmt800's did
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Do you think the harsh winters and salt have an impact on the drilled rotors more than the smooth ones?
rotors are steel they will develop rust in hours of just sitting even here in ca where they do not use salt or anything.
George B
¯\_(ツ)_/¯
I agree but around here it is a different level of rust. Stuff gets ****** fast! It's like any pit in the surface turns into a ridge around the rotor super fast. Here are some that are in the scrap bin today. I am not saying I wouldn't run them but I wonder if the life expectancy would be lower around here. I think @89Suburban has experience.
mrathell
I installed them on my 2015 Tahoe LT in the summer and they are performing as expected. This will be my first winter using them so I can't comment on how they will hold up in the harsh Wisconsin winter with lots of salt.
89Suburban
SE PA
mb1500
Rust does not discriminate. 3 years old 60k miles OEM components . Slide pin rusted to the bracket on this corner, other 3 rotors were just as bad.
okfoz
Not used their Rotors, but I am very pleased with their pads.
curbud
