First Oil drop-
pa31p
Dunno, haven’t had a gas engine in a while, seems little dark for 700 miles.
may be perfectly fine but expected lighter.
anyone know if factory fill on 5.3 for Yukon is actually synthetic ?
B-train
Not entirely sure what the OEM oil is....I thought the days of break-in oil were done, but I could be wrong. Coming from the generator world, I know that a lot of newer GM motors come with special oil from the factory. Cars and trucks may be different, not sure.
However, most newer vehicles have a RICH calibration for the first X# of miles. This is allowed to let the engine break in without running too lean and scoring a piston.
Did your mpg suck for the first few tanks? I'd run it for 5k with a good oil and OEM filter and try again. If it's THAT new, maybe 3k
GMT800 2005 Tahoe Z71
Navy Supporting Member
I am confused. Is this a new rig? Is in 2007-2014 section. First oil change since you bought this from another person or car lot? Can't tell much of anything with oil in a pan like that.
pa31p
pa31p
Thanks, Just noticed I’m in the 2014 section. not sure how to move it to > 2021
I see 21MPG on highway, but you may be right. just be a bit richer first few hundred miles indeed. i’ll drop it again at 3000 miles. put in a full synthetic. Just have 700 miles on it.
picked it up a week ago. engine runs like a sewing machine. can’t believe how quiet it is.
Hopefully a mod can move the thread and yes, I would expect the first oil change to be darker and use synthetic oil moving forward.
BADRIDES
New GM cars do NOT have break in oil. What you get on your first oil change is what came from the factory.
R32driver
I had our first oil change done at 5K miles and checked the oil level about every thousand miles up to that point. The oil on the dipstick looked basically like new clean oil for most of those miles. I would not expect engine oil to look that dark on any gas engine at 700 miles
Blackcar
A lot of times oil looks different on stick when you check level then when its in oil catch can.At 5,000 miles do you remember percentage left on dash?
R32driver
No I don’t look at that ever or care in the slightest bit what it says. I change oil at 5k on all my vehicles whether they be gas or diesel or run synthetic or conventional. Haven’t had a major engine problem yet in 36 years of driving
DuraYuk
Oil can get dark in an instant. It is nothing to worry about if the car runs well.
Just relax and enjoy it.
Also engines do not break in like the olden times. Everything is done at the factory.
I am not sure why your doing an oil change at 700 miles. But if it helps you sleep at night roll with it.
HotrodZ06
SoCal
The owner's manual (2021 Tahoe Z71) says not to tow any trailer during the first 500 miles and recommends that you change the engine oil before you first tow a trailer. I needed to tow our race car in an enclosed race trailer three weeks after buying our Z71, so I performed an oil and filter change at 550 miles myself just to be on the safe side.
Rod
WalleyeMikeIII
Sunny and Snowy Minnesota
Rod
Interesting, I don't recall anything in the 2022 owners manual about changing oil before towing, only not to tow during break in...
pa31p
pa31p
I dropped the oil early as I could not find any info what the factory oil is. I’d like it to be a full syntetic. The 5.3 runs flawless! really happy with it, like to keep it that way, maybe it does nothing but will drop it again at 4500 miles in two weeks.
Same reason I wax my car or wash it. sleep better at night. It may not actually do much for the car..
WalleyeMikeIII
No sweat, clean oil is always good oil.
Was just commenting on @HotrodZ06 post, who was stating the OM says to change it before towing...that info not in the 2022 OM that I could find, but would never be a bad thing.
I am changing at 5k on my 6.2, w/ its 8qt oil pan.
Drewphil
