tungsten
- Joined
- Sep 22, 2022
- Posts
- 339
- Reaction score
- 613
Only happens when it’s cold. Like really cold -15c. I suspect the water pump. What say you?
Exhaust leak+ noisy tensionerOnly happens when it’s cold. Like really cold -15c. I suspect the water pump. What say you?
Both tentioners just replaced,yes exhaust leak I know.Whats the screeching noise?Exhaust leak+ noisy tensioner
sometimes the ac tendsioner's tend to be noisy when it is cold out even if brand newI replaced them when it was warm.both were noisy. Now that it’s cold the noise is here.
Crazy sound. I guess I could remove the a/c belt and see for starters.
Just removed the a/c belt,had to pull it into garage for heat.Backed it out now letting it sit in the cold. 5f right now brrrrsometimes the ac tendsioner's tend to be noisy when it is cold out even if brand new
try taking the ac belt off before you start it in the morning and see what it does
my 03 did that and it was annoying as hell
ya that's pretty typical, I think that's why gm did away with the ac tensioner and went to a stretch beltSomething on my belt/pulleys squeaks slightly once in a while.
Usually on cold start in the mornings and it is wet or very humid out. Squeaks a couple of minutes and stops. PO said it has always done that. My mechanic was not concerned over anything he saw with condition of any belts or pulleys.
As far as I know theres only 2 idlers,replaced both.The main one is super easy takes 2 minutes.The a/c one is kinda a ***** if truck isnt jacked up.Im a big guy,as far as belts go Im cheap lol.I had same noise last winter and was belts. Can I ask, unless the belts way way new, why did you not do all tensioners, idlers and belts at the same time? What am I missing?
You know maybe its the belt and bearing making the noise? Crazy sound for a belt to make though.Ill stop and get new ones one day.At least now I know what it is I think.Didnt drive it with the a/c belt just hanging behind the main belt.Was scared it would get tangled up.Replace them now, you cheapskate and use good quality belts and splurge a bit.
it acts as a dehumidifierSo what is the function of the a/c pump in winter?
It comes on when defrost is engaged.
Thats what I thought,My last truck had no belt ,it broke so I just left it until summer.Didnt have any issues,probably save on gas.it acts as a dehumidifier
