2018 Z71 Skid Plate Part Number
Just joined the forum the other day. I've had a 2007 Silverado LT and finally had to trade that and my work car in for a vehicle that's better for our family. Decided to Join the tahoe family. Anyways, Glad to move from the silveradosierra forum to the Tahoe Yukon.
I have a 2020 Tahoe LT. I'm not happy that there are no tow hooks and the air deflector scraping the ground every time I pull in my driveway. I've already researched adding tow hooks with the different fascia piece that has the holes for them.
I'm still deciding whether to trim the air deflector or spend the money and get the PPV deflector. Now to further complicate things I started researching if the z71 front skid plate could go on my setup and if so which route would I need to go with the lower air deflector. Skid plate isn't too important to me and I'd like to make a move on the tow hooks and lower air deflector soon before hunting season is here. Does anyone know if the z71 skid plate works with the LT bumper? if not, then I'll stick to tow hooks and air deflector and be done. Thanks for the help.
bumper has nothing to do with any skid plates, the difference is the lower valance "IF" you wanted to go with the midnight edition then you could use it with the very optional skid plate that would fit with that valance otherwise your regular valance will work with the regular skid plates as they are tucked completely under.
you could take the very bottom piece off of your valance and gain and inch or 2 clearance or just cut it as needed.
as far as midnight edition I am thinking silverado and the bumpers for the silverado may be different, either way the regular skid plates just bolt on all k2's.
cardershack
Thanks for the explanation Doubeleive. Sounds like its separate and if I wanted to add it I could do it later. Please forgive me but explain what K2 is. This is my first Tahoe. I've had nothing but trucks so wasn't sure what K2 means.
it's just a term for the gm platform 00-06 is gmt800, 07-14 is gmt900, 15-20 is k2xx, 21+ is T2xx
those year break downs are each on there own platform for the most part same frame design, software, etc with some minor differences depending on when they made small changes and it breaks down a bit more to 3-4 engine codes per platform and transmission codes.
for what you are looking for these would work this guy sells them all the time, you would just need to get the self taping bolts, regular bolts will not fit right, when installing do not over tighten the bolts at all they will strip easy then you have to go with a larger bolt
cardershack
And are these the only two pieces that are part of the skid plate package? one for the front and one for the rear?
those are it except for 1 for the transfer case which is a small one, they are often sold for the colorado but it will fit all from 00-20
this is about the cheapest one
cardershack
I got under my Tahoe yesterday because I'm about to add tow hooks and the fascia with the cutouts for tow hooks. I don't have skid plates but I have a plastic or rubber splash guard. do the skid plates replace these and bolt up the same? if so I may get these off eBay and swap them out. I apologize if this has been answered earlier in this thread but I haven't had time to go back and re read it all. Thanks for the help
replaces the plastic one, bolt holes are the same you will need a couple more bolts though because the metal skid is a 2 piece and requires I think 2 more bolts.
I presume the plastic one you are talking about looks like this?
cardershack
Yep thats what I have under there now. Is there a part number for the hardware? I looked at the Ebay seller you posted and considering buying them. I can message him as well to see if these come with hardware.
Sparksalot
Bastrop County, Texas
the one I linked on ebay will fit and work, he doesn't provide any additional bolts. the bolts you need can be found under any gm suv at the junkyard they have used the same bolts for the last 20+ years they are self taping when you start the bolt it will make a thread in the hole. dealer parts department will have them but they are $7 or 9 each, maybe more I just grabbed a couple off the ground at the junkyard, don't over tighten them because then you have to start over with a larger bolt they strip the metal on the truck fairly easy
mikez71
Any chance these might bolt onto a gmt900? Maybe flatten the one bottom corner?
mikez71
They look pretty close...
If the front screws spaced the same I'd definately take a chance with it.
Unless you know something specific won't work...
mikez71
This guy lists a skid plate for '07-'18 trucks as well.. Says a metal bracket must be removed from 14+ trucks...
It is 3/16" thick..
50% thicker than rod louver's, and costs 50% more.
This guys lists a skid plate for '07-'18 trucks as well.. Maybe a typo? But it is 3/16" thick..
50% thicker than rod louver's, but it has an "IF" logo cutout in the corner.. and costs 50% more as well..
I have looked at the izzy before and just assumed it was some kind of typo, based on there photo there is no "sheet metal" to remove from the plate and there is none on the k2 to remove either, the truck in there photo is modified for "more free travel" i.e. desert.
I sold my k2 z71 plates a long while back when i got the CST lift which has different plates but I still have the plastic ones. the front looks "close" but the actual curvature is different and the rear does not line up on the plastic one anyway, the metal k2 plates use 2 more bolts (self taping) and the actual bolts are the same thread and size as 00-20. so if anyone needs any there are plenty laying around in junkyards rather than paying $9 or $12 each that the dealer will want
I tried mocking up some when I did have them and they do not match up at all.
in the photos the gmt900 is on top and the k2 on the bottom
3rd photo is the k2 silverado
last photo is the 12 denali with the lourved front and oem z71 front diff plate
I just found this on GM parts website - it IS the original z71 front skid plate:
https://www.gmpartsstore.com/oem-parts/gm-part-23475140-underbody-splash-shield-23475140
Pretty good deal - not sure what the shipping would be...
that particular skid plate only fits a very specific z71 MIDNIGHT EDITION front bumper, basically a limited edition only. does not fit a standard bumper.
so while YES it technically fits a 2015-2020 IT DOES not, unless you have the special front bumper.
this is not noted anywhere like in a fitment guide
Oh Kee Pah
MAINE
That is actually INCORRECT.
If you look at the front bumper of the z71 edition, you will see that the chrome piece you see from the front view is a part GM is calling the "VALENCE"
That valence IS specific to the z71 front bumper (hence the z71 advertised special front fascia)
However, the SKID plate mounts below and behind the bumper...I don't think it really matters what trim level you have.
If you look at my post #21 in this thread, you will see my the photo of my fingers sticking up between the skid plate and the front bumper.
Conedaddy
