Matthew Jeschke
As many of you know, I did the 6.0L swap. I can start the truck no troubles with some tuning now. However, if I drive to store say, buy some groceries, then try to start the truck it doesn't want to start. I have to crank it quite a bit. I assume the fuel pump is struggling once it's been heat soaked.
That aside, I'm trying to figure out if the 6.0L has the same fuel pump specs as the 5.3L? If so I'm just going to order an OEM fuel pump module.
Any clue if it's the same fuel pump 5.3L & 6.0L?
