NEED HELP truck doesn’t warm up literally - SOLVED
Jonny_96tahoe
So I have this 1996 tahoe with a 5.7 I’ve had for awhile did an engine swap from a Chevy pickup truck same engine just in the summer one thing I Always noticed my gauge would never get to operating temp so I thought maybe it has a colder thermostat but I’m not sure this is pretty cold for a motor and I get like no heat lol so next thing is probably change that out. But I’ve read that didn’t help some people. Coming close to winter so tryna see if anyone else has had these issues because I’m lost with all the shit I’ve read up. I also need help finding where all my vacuum hoses go I think I got them right but wanna make sure! Can’t seem to find a proper diagram or video here’s a pic of my temp gauge after running for 20 mins and if you guys need any pictures of anything else please let me know
Jonny_96tahoe
Jonny_96tahoe
After running & driving btw! Temps were that low always are even in the summer we would maybe see highest of 130 on the gauge. I know there’s a lotta things to check but definitely wanted to make this for more ideas. Thanks a lot guys.
exp500
Buy a cheap IR temp gun and start shooting everywhere to verify what you have and don't have.
Start at thermostat housing and block/head temp sensors.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum.
Sorry but I cannot make heads or tails of some of what you are saying. Sentences jumbled together. Are you saying that you had the same problem with old engine? Only since the new engine? Used the existing thermostat that was in the swap over engine? Did not change the thermostat when swapped engine? If not, then why not? Cheap enough to do. Change it and see what happens. AS @exp500 said, yes, get the temp gun and get solid info instead of guessing. Condition of radiator? Sure the temp sender is working correctly?
Do the OBS cooling systems need the same restriction as the NBS in the return line to the surge tank?
I do not believe so but I was wrong recently about a cir clip location for shaft reinstall and now I am gun shy on "maybe/maybe not" questions. :banghead:
Jonny_96tahoe
Jonny_96tahoe
Hehe my bad was a little stoned before bed last night!.so I never had this issue with the old motor and didn’t get to grab to many old parts off it sadly. Swapped motor seemed fine just ran super cool which I was fine with in the summer but now it’s getting to - weather here in Canada so time to figure this out. Radiator seems good no leaks or anything anywhere. & Temp sender is on the driver side of the block right? Haven’t gotten to that yet but if that was broken would that not let that truck actually warm up because I barely got heat. Temp gun & new thermostat will give that a go first thanks everyone!
Jonny_96tahoe
Jonny_96tahoe
OUU another question for y’all I noticed after swapping this motor as well after abit my brakes got way more squishy pads look fine still brake fluid is ok and hey when the truck is cold my breaks will be super soft but get to a point about halfway where it instantly locks up, Until it warms up then they just stay soft but stops the truck decently. 1 abs wire is cut and has been since the last motor. So I’m thinking this motor has something wrong with vacuum and that’s why I was asking about that to just forgot about the brakes acting up to!
Jonny_96tahoe
Jonny_96tahoe
Hopefully I made this make sense With the pictures!
I was responding to the statement in your initial conglomeration of words that the gauge read low. Yes, it could be reading correct, since the heat output is crap as well. Likely, as has been stated by @YukonGTmaster, that the thermostat is stuck open. I personally would never change ANY engine without doing a new thermostat. Also, you should post the brakes problem in the correct section.
Also, put the pipe down before posting.
Jonny_96tahoe
Jonny_96tahoe
Ahaha thanks man! I’m still a newbie so I’m getting used to this. I’ll go find that section thanks again!
east302
Mississippi
In your photo below, the blue line is a vacuum and it connects to that solenoid on the firewall. Your red line would go to a plastic valve on the heater lines.
When you select the “Max” detent on the a/c temperature dial, this solenoid is energized and vacuum is applied to close that valve on the heater lines. The intent is to maximize a/c performance by shutting off flow to the heater core.
My 98 is plumbed a bit differently, that blue line connects to my PCV valve fitting on the driver side. Your vacuum line appears to connect to the EVAP purge solenoid. That draws fuel vapor into the intake from the round canister on the driver side - your last photo.
That seems odd to have the water valve solenoid connected to that. I want to say that it would be an open vent on that port but maybe someone with a 96 or 97 could confirm. My 98 has a different style Evap purge valve.
What vehicle did the new engine come out of? Pickups did not use the valve on the heater lines. On my 98 truck, it does not have the port on the PCV fitting while my Tahoe does.
1998 Truck PCV fitting:
1998 Tahoe PCV fitting:
The red arrow points to the vacuum that connects to the water valve solenoid.
It probably doesn’t really matter as neither would account for low coolant temperature, but if the solenoid is constantly energized then it would impact heater performance. Unplug the solenoid in that case to see if it changes. There’s also a spring-loaded plunger on the water valve at the heater lines. It’s the shaft for the butterflies in the valve. If it pushes up and down with the engine running then the valve is open.
As for the dash gauge, most report it running at about this point with the 190 (or is it 195) degree thermostat:
The intermediate tick marks don’t really correspond to any number (the first half of the gauge is a 110 range while the last half is only 50) so it’s just an approximation…similar to how Ford just wrote NORMAL on their gauges and called it a day.
The gauge sender is on the driver side head. The coolant temperature sensor is right by the thermostat. That is what the computer uses. You’d need a scanner to read the value and, if you have one, would be a good thing to know.
Couple questions-
Did you bleed the radiator?
Are the heater lines hot - too hot to hold more than a second or so?
Does the upper radiator hose ever get comparably hot?
Jonny_96tahoe
Jonny_96tahoe
Dude!!! Thanks for all the suggestions Motor came out of a 95 I believe Chevy k1500, I believe the old motor that came out of my Tahoe tho had that driver side vacuum thingy the motor now from the k1500 seems to not have it beside the throttle body pictured below & yes made sure no air was in her! & 1 heater line gets barely warm the other gets a decent warmth to it no to hot to touch tho even the upper radiator hose doesn’t get hot hot I can hold it after a 30 min drive :0
east302
Mississippi
If your replacement engine included the intake, then it looks like a 96 or 97 since you don’t have the throttle body injection. Maybe @YukonGTmaster can let you know if his water valve solenoid is connected to the evap purge or to the PCV. I think he has a 97.
So the heater worked before the swap? If so, that should rule out a blocked heater core. Just for kicks, find the metal plunger on the heater hose water valve and see if it moves up and down. If it’s stuck up or in, then the valve is closed.
Heater hoses are connected correctly?
I’ve heard of people having a clog in the heater inlet hose at the quick connect causing poor heater performance. I’m not sure if it would explain your overall coolant issue, but it may be something to check. Pinch the ears on the plastic retaining clip and pull the hose out.
It will have a plastic orifice inside it restricting it somewhat, but if you pull the hose you can see if the connector in the intake is blocked. Go ahead and buy a new plastic retaining clip for it beforehand, it’s liable to break. Parts store have them, usually available separate from the complete quick connect fitting.
Otherwise, I’d be real tempted to swap that thermostat out.
That connection, circled in yellow, can be a SOAB to get open if severely corroded and/or rusted. I have seen them leak where they thread in and then break off during the removal. Thankfully the pipe thread there is very large and if you work at it, you can go down one side of the broken off section and use a sharp small chisel and break out the pieces until it collapses in on itself. The design is crazy stupid.
Jonny_96tahoe
Jonny_96tahoe
Ya heater and all worked before the swap! I’m gonna check everything everyone recommended and first probably change out that thermostat or at least test it and see if it’s opening and closing properly & ya I’ve delt with that heater hose inlet it’s a b****
ivin74
05 NBS Nali
Htown, Texas
Feel the coolant hoses to see if they are hot. If they not hot, replace the thermostat.
Test again if it's still not getting hot, remove the clutch fan and run the engine to see if it heats up. If it heats up your problem could be the clutch fan
Holt50
It's the temperature sending unit I just bought one today cuz mine is doing the same thing. I took a wire from the negative to the connector just to test my gage to see if it was working fine and it is.
BadDaddy2003
