Show off your 2015-2020 lowered tahoes and yukons
6Parkers
Pics? Did you do free travel mod?
No free travel mod. No rubbing up front and after putting in a spacer it appears I could have been sitting on the driver side bump stop. I did trim it per the instructions. The passenger side look fine but it also sat just a little higher. I put the spacer in on the driver side b/c when it measured it was a bit lower. I don’t have the numbers right in front of me but the driver side front/rear are now exactly level. I am not sure why but the passenger side still sits a little higher but the ride has greatly improved as well as now it doesn’t look squatted.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
View attachment 373570View attachment 373571No free travel mod. No rubbing up front and after putting in a spacer it appears I could have been sitting on the driver side bump stop. I did trim it per the instructions. The passenger side look fine but it also sat just a little higher. I put the spacer in on the driver side b/c when it measured it was a bit lower. I don’t have the numbers right in front of me but the driver side front/rear are now exactly level. I am not sure why but the passenger side still sits a little higher but the ride has greatly improved as well as now it doesn’t look squatted.
Nice!!!!!
NIevo
Lewiston, ID
What is the "free travel mod"?
I have a bit of rubbing on mine.
Free travel mod probably won't help with rubbing. It's where you cut out the metal piece that the original rear bumpstop is attached to, and install the bumpstop on the bottom instead.
Chevy*808*
Why sell the 24's? That Tahoe was bad as hell with those wheels on it.
My gf giving birth feb next year she wanted more of a daily no worry of bending or cracking the rims since hawaii Government spend all they’re moeny building the rail that’s ain’t even don’t yet for the past 8 years roads all mess up hahah
BADRIDES
I have asked you many times, Where did you get the 24's from? What size tires were on the 24's?
Staggered 02
Well it's been a while. Time sure flies. My work assignment in Louisiana ended over a year ago. I've been back there a few times for a few weeks at a time. One of the most recent Escalade pics. The High Country & the rest of the rides have been undergoing through the transformation processes as well.
john1989
