Clunk or groan when turning
Amaster
Laramie wyoming
I'm having some trouble with a groaning sound coming from the front end when I turn in a parking lot or something like that in my 2011 gmc yukon it's usually once every couple of days I'm wondering what it could it be. It really isn't something to big on my list but it's there.
GMT800 2005 Tahoe Z71
Navy Supporting Member
If you could record, it would be easier to decide what it is. But, sounds like could be power steering that is low on fluid. Have you checked the fluid level? It could also be somewhere on your front steering or suspension components with bushings.
A
Amaster
Laramie wyoming
Update other than struts looking pretty nasty all bushings in the front end look good. Also checked my fluid reservoir it checked out.
A
Amaster
Laramie wyoming
Plus also sorry for no video it does every once in a couple of days while in 2wd plus I thought I may of gotten the sound today while making a video but can't upload it.
A
Amaster
Laramie wyoming
Here are some pictures I took of the front suspension.
That video of the noise would really help, if you can. At this point, it is just guessing.
I tell ya, I thought I heard it when you said it is the steering wheel or clock spring noise but the other faint noise sounds like dry bushings. Spray some silicone lube on sway bar links and control arm bushings or just any suspension or steering rubber and see if noise is gone. Or before that, others here may have ideas of what they hear. That squawk noise bugs me though.
A
Amaster
Laramie wyoming
I'll probably try to lube the clockspring when I fix the airbag light.
AdrienR
