SpaceBaller01
- Joined
- Sep 8, 2022
- Posts
- 30
- Reaction score
- 47
My apologies, I thought I set this to notify me when I got a reply.Crickets are a PITA.
This is a 2004. Unfortunately the thermostat has no degree rating on it. I just know what I put in was 185, from the Amazon page. I'll have to give them a call on that one.Correction, depending on the year of your vehicle they could have used a 195F as well. I do know that there are different temp options for performance or industrial applications of the same engine.
I'd double check to make sure what the OEM one you removed has stamped on it, or check with a dealership parts dept to see if they can give you the exact spec from new.
Unfortunately I have no idea. Bought the truck earlier this year with virtually no history. I'll try that return line trick though.When this "too cool" problem started, what work had been done just prior? Any chance you're running an aftermarket radiator?
Read this: https://www.tahoeyukonforum.com/threads/cold-case-radiator.135572/post-1699853
You could try pinching the small return line that goes from the radiator to the surge tank to see if that makes any difference.
Nope that's wayyy too ahead of the stuff I do lolDid you change the settings in the ECM to make fans come on sooner? If not, it will always run the same temp.
Honestly I'd be surprised I pretty much followed it as It came out. Has not overheated at any point. It did go to temp on like the 2nd or third time I drive it after Installing it a day or two after. But hasn't come back since.If the weather where you are is already cool, a thermostat stuck open could explain your heat feeling cooler than normal.
Is it possible the thermostat is stuck open or backwards?
Is that possible on the GM stats @OR VietVet?
I know I saw some people on Wrangler forum did not pay attention to how the original stat was positioned in their 4.0L and ended up putting the new one in backwards. But I forget what the exact implications of that reversal was. I am not sure, but I think they started off cold, then overheated after the stat opened (which was closed because it was in backwards...).
Yeah... I wasn't insulting your mechanical abilities. I haven't found out if the casting for the thermostat housing would even allow the part to be flipped like it could on the Jeeps. I was just trying to talk out some of the possibilities and an open stat was one of the things I was thinking of as at least being remotely possible. Even then, the engine would get up to the normal operating temperature of somewhere close to 210 F +/- a few...Honestly I'd be surprised I pretty much followed it as It came out. Has not overheated at any point. It did go to temp on like the 2nd or third time I drive it after Installing it a day or two after. But hasn't come back since.
A heat soak takes place every time you get the engine to operating temp and then shut off. The engine temp climbs higher then because there is no air flow. Then when it hits its peak temp, it drops. If you have electric fans they can stay on after shut engine off till a temp sensor sees the temp drop to a certain point.Could you clarify what you mean by heat soak?
Hee-haw was always on after the Dukes Friday night when I was a kid. I was too young to pay attention to skimpy dressed ladies.Coulda called someone on the rotary phone... BR-549?![]()
I'm guessing it's clutch driven. It does have a shaft driving those fans.Does this have electric cooling fans, or a clutch fan?
Don't worry I didn't think you were meaning to there. Like you've mentioned we're trying to rule out some possibilities and no harm to askYeah... I wasn't insulting your mechanical abilities. I haven't found out if the casting for the thermostat housing would even allow the part to be flipped like it could on the Jeeps. I was just trying to talk out some of the possibilities and an open stat was one of the things I was thinking of as at least being remotely possible. Even then, the engine would get up to the normal operating temperature of somewhere close to 210 F +/- a few...
Cooler than normal most all the time and occasionally almost normal random other times.
This is a head-scratcher, but I am sure someone can help walk you through this diagnosis.
In this case, yep it's definitely clutch driven. Just checked, connected to water pump, single fan.If the shaft is driven by the water pump, it's a clutch fan (one). The electric fans are dual and are not connected to the water pump.
Unless the coolant is dirty or has big chunks of rust coming out with it when you drain down, I would pour it back in.Don't worry I didn't think you were meaning to there. Like you've mentioned we're trying to rule out some possibilities and no harm to ask.
Honestly I'm pretty tempted to go ahead and just try another thermostat. I happen to have one forgot, just didn't want to change out the coolant again if I don't have to.
