SpaceBaller01
- Joined
- Sep 8, 2022
- Posts
- 30
- Reaction score
- 47
So I've replaced the Thermostat (after noticing that the coolant reading no longer goes higher than 185 degrees. The new one is a GM, should be stock 185 degrees. However my coolant temperature doesn't go any higher than 185 degrees still. Intermittently getting a CEL for too low coolant temperature, if reset it'll go away for a while but comes back eventually. It doesn't seem to matter how long my trips are, goes no higher than 185 degrees. It is affecting the heat as well, am getting heat but not as hot as I would expect (like setting to 84 gets 74 degree level).
