I think I destroyed my Steering Rack
MarshMarlowe
I replaced inner tie rods on both sides today. I REALLY had to put a lot of effort into breaking free the inner tie rod mounts. I'm guessing that destroyed the rack. Maybe I was supposed to use a backup wrench. When I started the truck, what I'm pretty sure is power steering fluid sprayed forcefully all over the floor, the underside of the engine, even up onto the bottom of the open hood. It was dramatic
Is this for sure my power steering rack failing? Are the reman units on RockAuto worthwhile?
Thanks
Geotrash
Dave
Richmond, VA
Thanks
Yikes! Yes, I just installed one from Rockauto and it’s fine so far.
MarshMarlowe
MarshMarlowe
Where is the fluid coming from?
Hard to say for sure as I didn't witness it. I will have to crawl back under the truck, but it's a big mess under there. I needed 3 bath towels to clean up all the fluid.
I noticed the boot on the driver's side is soaked, and the tie strap blew off that boot common to the rack. The clues I have point to the rack. I'll have to do more investigating. I went ahead and ordered a new rack from RockAuto as they only had one reman AC Delco unit in stock. See photos
GMT800 2005 Tahoe Z71
Navy Supporting Member
One good thing about those parts with fluid all over them, they will never rust.
MarshMarlowe
MarshMarlowe
Well I feel like an idiot
The old oil filter gasket stuck around, and I installed the new filter on top of it
The 'fluid' that sprayed actually came from the oil filter.
Note- fresh oil smells and looks a lot like power steering fluid
Derp
lyncht1967
great, crisis averted....live and learn...we've all done it or came close to doing it if we never got tips. my dad wasn't a car guy so i never got any..did the same thing when i was 17 on my toyota corolla..let loose in the driveway on start up...
lol I did that once about 35 years ago....
young, dumb, broke as a joke, drained the oil, changed the filter, filled it back up, started it up and went to go drive around the block, backed out of the driveway to see a giant puddle of oil. yep same thing old seal stayed on and got twisted up with the new one, what a freaking mess
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Glad it was an easy fix. I envy you 2WD guys. I hate all the extra junk under my truck for the 4WD system with a passion. I never use it.
Buford bubba
