Sparksalot
Bastrop County, Texas
Yes. So you have just the pre-collision warning system or just a blank hole… LOL
if you have the warning system, you’ll have the little simple car icon in the bottom of your gauges that’s green or yellow when following a car and there is a button on the left side of your steering wheel to set the distance it reads.
If you haven’t experienced it yet, it’s a little unnerving as it starts flashing in th windshield and vibrating the seat. It’s just a warning system, does not apply the brakes. But it’s saved my butt a few times when the people on front of me are driving like a-holes
I’ve been experimenting with the pre-collision settings. I wasn’t sure it was working then yesterday…
Driving through town and a pretty girl on a bike... suddenly the seat is buzzing and red bars flashing. Something got everyone ahead out of sorts. It works like a champ.
dpollak81
Lincoln, CA
Yeah unnerving at first but it’s actually pretty helpful. There’s been times where I just didn’t notice the speed difference up ahead of me and it alerted me and another time when someone’s brake lights weren’t working!
LT1ZOB
Hauled my Z06 to Corvettes at Carlisle
LT1ZOB
Took first place in NCCC judging and got a surprise “celebrity choice” award. Record attendance year, 40th anniversary of Corvettes at Carlisle. Now that it’s spotless, I’ll be at LS Fest in a couple weeks running the museum track and quarter miles.
Waited until the field emptied out to pull the Tahoe in and load.
Tonyv__
Bucks county PA
Anyone else having this paint rub off on the inside of the rear doors? Driver side is rusted already. This pic is the passenger side. I’ll probably just lightly sand and dab it up with some touch up paint to prevent further rust. But I assume it will come back
CMoore711
Is this on your rear doors? I have it in the same spots on my rear doors.
Ultimately I think the bigger problem is the door alignment which is causing enough contact with the door and the rubber door seal on the bottom to rub the paint off over time.
Tonyv__
Bucks county PA
Yeah. Wasn’t sure if it was common or if I have bigger issues lol
Any of you fine folks need some new rotors for the rear of your rigs??
RST Dana
OH
Price?
LT1ZOB
This was happening on my 16 rear passenger door. I touched it up, put a piece of xpel over it, and that did the trick.
Thrust
ICT
Added Hellwig rear sway bar end links to my Hotchkis sway bar. Do yourself a favor and ditch the factory end links.
Also bled the Brembo calipers using a snap on diagnosis tool to energize the ABS valves. Seems to have done the trick as the brakes work great.
Sparksalot
Got some crossbars for the rack. some assembly required.
SpyShops212
Took it to the dealer in Houston called SeWell Cadillac to have the OEM windshield replaced and the bottom outside trim under the windshield which almost all K2XX trucks get warped. If you anyone goes and check you will see what I am mentioning. I figured it would be the proper time to replace the trim piece while they are at it. I will pick up tomorrow and post to let everyone know how it went. I did make a video and took lots of pictures just in case they mess something up. I also noticed on my previous windshield that there was spots that you could see everywhere when the sun hits it.
Dh1280
