TPMS relearn procedure without tool
dkad260
I don't have the TPMS tool for resetting the position on my 2012 Yukon.
I set the parking brake, turned ignition on, pressed lock and unlock on keyfob to initiate the procedure.
Once the horn sounds, I let some air out of the LF tire but I won't get the confirmation honk.
Can this procedure be done without the tool?
Amaster
Laramie wyoming
I'm not sure about your year but on mine when I got a flat and got patched. I just drove it down the block, and it figured itself out. But you probably need the tool.
yes you need the tool, you can find cheap ones on amazon or ebay, like $15
D
dkad260
To clarify, the sensors work, but the positions are wrong.
D
dkad260
Yeah it’s well worth the $15. I bought one and it beats sitting there messing with the air pressure. It’ll usually trigger the sensor in like 2 seconds or less.. makes the whole process less than a minute
This is the one I got if you were unsure
That's the one I ordered, thanks. :waytogo:
Smokin Denali
