(Solved):Change wire and plug now code
Amaster
Laramie wyoming
I'm having some trouble I just got the plugs done on 5.3 and I'm getting a code for miss fire on 2 well some people have said wires so I changed the wire from the plug behind it to that plug and still have the code help
wjburken
Eastern Iowa
Are you getting a misfire on the same cylinder after you swapped plugs?
You checked the gap on the plugs before installing, correct?
Pull the offending plug and inspect for any damage like a crack in the insulation and proper gap. If it looks fine, swap with another cylinder and see if it follows.
If it follows, it’s likely a bum plug.
As Wade said- check the #2 plug. At least it's an easy access. What plugs and from where did you get them? Still have the boxes?
Cort84
