24x14 Offroad Wheels On An AT4
Chad G 1979
I sure hope you dont run into any surprises when cutting up your rig, like framework or electrical runs. Itll look sharp when your done though.
sanman28
U have a body shop lined up for the cutting and refinishing of metal?
ProfeZZor X
ProfeZZor X
High Country
Actually I do... There's a body shop out in Hollywood that does custom fabrications, designs, wraps, and everything else under the sun for everybody. From Rolls Royce to Renalts... Brand new or vintage. They also have their own YouTube channel and Podcast.
Remember, I'm not putting on 35's, 37's or 38's. This is the same size 33" tire as the stock tire, just a little wider. So I'm not required to do any major cutting that will totally change the entire look of the wheel well. Even with yesterday's test fitment, the front of the tire was able to tuck inside the bumper (you can see that in the video). It did rub on the felt liner, but that could be pushed further towards the front with zip ties. Once everything all comes together with the lift installed, I'll know where I stand with cutting.
ProfeZZor X
ProfeZZor X
High Country
Lmao, yea just a smidge
I'm referring to the stock height. The rim itself might be wider, but the tire width and tread pattern is narrower than the rim.
sanman28
Nice. You have a vision and you are following it through. I like.
ProfeZZor X
ProfeZZor X
High Country
Having the 3" Ready Lift kit installed today at a local shop. This off-road shop also does NorCal mods (fender modifications) and cuts running boards too, so I'll have them do everything today so I can hopefully put the wheels on this week.
I can't promise pictures of the actual cutting (safety protocols in-shop), but I'll certainly provide whatever step-by-step pictures I can get.
Wish me luck.
sanman28
Wish me luck.
No going back now!
ProfeZZor X
ProfeZZor X
High Country
No going back now!
They claim they don't have time to cut the running boards today, so I may have to wait until they're done with the lift to see if they can still cut them today. They also have other customers to tend to... There's always other shops I can go to, but I'm tired of driving cross town for all of this to come together. I'm in the final stretch, so what's a couple of days waiting if the trimming doesn't happen today...
sanman28
Just take the boards off for a bit.
992dr
Eastern N.C.
Wish me luck.
Good luck man, definitely lookin forward to the end results.
Sometimes if you get in good with the shop they'll do you a favor, like taking pictures or letting you watch whatever work is being done. Don't ask me how I know ;) I have a hard time trusting people working on my Tahoe.
ProfeZZor X
ProfeZZor X
High Country
That's only a piece of the puzzle. I'd still need to cut the fenders.
More importantly right now is for me to see how far back I can cut into the structure underneath the fender liner. I haven't pulled the fender liner back to see how much metal there is I need to cut away, so that would be where I need to start at before I randomly start hacking away, and the inner/outer measurements end up being way off.
ProfeZZor X
ProfeZZor X
High Country
The lift turned out great. It'll take a little getting use to driving higher, but i guess i can't complain. The lower part of the body extends just above the widest part of the tire, so that's a plus for getting the wheel to turn a little bit more.
Next Saturday I'll be taking it back to my main guy where I got my tires and powder coating. He's just as anxious to see the wheels on it as I am, so he's going to try his best to get the cutting done in one day. I told him we can do little by little in sessions (45 miles away), and come back over the course of a couple of weekends until it's done, but he's determined to knock it out in one session.... Okay.
ProfeZZor X
ProfeZZor X
High Country
The wheels are officially on the AT4. I'd like to thank 4Play wheels, the lovers and haters, and everything and everyone that made this endeavor possible.
The cutting is currently being done, but there is very minimal impact on the body itself. That 3" lift made all the difference in the world. What they will have to do is trim the running boards about an inch and a half, and that's being very generous. The front wheel well only requires a minimal amount of cutting at the very bottom. The wheel does tuck inside the fender, but to be on the safe side and avoid any possible rubbing, I'm having them trim a little off that lower fender well, and a small amount of the felt liner.
Once it's all done and I make her all shiny, I'll post some glamor shots.
ProfeZZor X
ProfeZZor X
High Country
More pics from today's install. We ended up not cutting the running boards. Instead, we shifted them back an inch and a half and recapped them so it's flush with the new fender cut.
I know a few of you expressed your concerns over the amount of cutting involved, but seeing what the lift did for this project, I was confident the cutting would be minimal. The felt liners were cut, but I will zip tie them once I fine tune the areas that occasionally rub. The only rubbing I've had was going up or down at an awkward angle. I did experience some caliper clearing issues when I test drove it. By the time i returned back to the shop, there were metal shavings all over the wheels. Part of the spokes were grinding on the calipers, so they added a 1/8th inch spacer. The spacer is thin enough not to make a huge difference in the existing cutting we've done.
In all it does have a more aggressive look than anything out there, but that's not what I was going for. Like most off-road enthusiasts, I wanted my AT4 to reflect my lifestyle and likes. It may not be everyone's cup of tea, but I'm the one that admires and drives it at the end of the day, so that's really all that matters.
Thanks again for your positive and negative feedback, your subscription to this thread, and overall support.
BrokerThis
'22 Denali Dmax
Detroit
Not particularly my style, but you have done a great job and it looks fantastic so far. Been interesting to read/take the journey with your writeups and updates over the past couple months as it progressed.
Can't wait for you to post some great action shot pictures to show how well it will perform
ProfeZZor X
ProfeZZor X
High Country
Glam shots..
enigmaspeed27
