BF Goodrich AT KO2
Marcos1629
I have a spare set of 20 inch rims for my 06 tahoe Z71 I wanted to put some BFGoodrich KO2s 275/55R20 on. My truck is at stock height I wanted to know if these tires will rub.
MassHoe04
Western MA
When I bought my 04 Z71, the PO had some nice Torque Thrust rims on there. He was going for more of a "street" look. The tires he had on there were low profile sport-treads. Just too slick and too fat for me in New England winters. Would be like banana peels...
Anyway, the tires I had on there were Yokohama Parada.
285/50 R20
Mine did not rub. Although... I tend not to turn the wheel lock to lock anyway.
I don't think yours would rub.
Here is how yours and mine compare:
Tire 1
275/55R20​
Tire 2
285/50R20​
Difference​
Tire Height (Diameter)
31.9 in​
811 mm​
31.2 in​
793 mm​
2.16%​
Wheel Size
20 in​
508 mm​
20 in​
508 mm​
0.00%​
Sidewall Height
6 in​
151 mm​
5.6 in​
143 mm​
5.79%​
Tire Width
10.8 in​
275 mm​
11.2 in​
285 mm​
3.64%​
Tire Circumference
100.2 in​
2,546 mm​
98.1 in​
2,491 mm​
2.16%​
Revolutions per Mile
632​
646​
2.21%​
Revolutions per Kilometer
392.7​
401.4​
2.21%​
Speedometer Difference:
Tire 1 (mph or km/h):
20​
40​
60​
80​
100​
120​
Tire 2 (mph or km/h):
19.6​
39.1​
58.7​
78.2​
97.8​
117.4​
While our truck body generations are different (NBS vs NNBS), I run 305/50x20 Michelin Defenders tires on my 07 Yukon XL Denali with no rubbing. This tire is 32 inches tall, and I have no issues driving in NH winters.
Your 800s were designed to run the 265-70-17 tire which is basically the same height as the ones you want to run. The 900s use both tire sizes interchangeably. You should be fine.
The only caveat is the wheels, they will work fine if the offset is stock or close to it.
Marcos1629
Marcos1629
So I went an got some 275/65r 20 for all 4 tires instead of the 275/55r20's like I mentioned above. I took a picture of the front driver side tire how it'll sit with the full weight of the truck on the ground. It looks like I'll have to put a small lift kit and possibly wheel spacers on to get this to work. The black wire in the 2nd picture is the only thing that the tire will rub when I had the wheel turned close to lock
S33k3r
Dallas, Texas
Can you not relocate the wire? I can't tell from the pictures. Also, I wouldn't hate seeing pictures of a mockup. :)
adventurenali92
Big Bear Lake, ca
I ran 265/65/20s in a Michelin LTX A/T2 setup that came off a 2019 F350, on my 20”6 XL Denali for about two years. I had a leveling kit installed on the front and my drivers side tire rubbed the inner fender at the slightest compression of the front shock and at even like a 1/4 turn of wheel. It was very annoying. And the shop assured me the leveling kit not allow this issue to happen. If you’re dead set on running the 65 series tire you’re going to need to run I’d assume at least three inches of lift in the front to not have any rubbing issues.
The other problem I had was those 65 series tires are stupid heavy so they killed my fuel economy I noticed a considerable power loss. If you regear than you won’t have those issues but that wasn’t an option for me.
Before that set of tires I ran a nitro 265/60 series tire and that was the best experience. Much bette ride quality over the stock 55s and no rubbing issues whatsoever. When the 65s I had were finally worn down I replaced with a 60 series Michelin defender LTX and couldn’t be happier. I left the front level kit on because I like the leveled look, and the 60 series tires don’t look smal in the wheel wells at all. Plus the ride is so much better on these tires and my due mileage has gone back up a bit and it doesn’t have the noticeable power loss anymore.
Marcos1629
Marcos1629
Yeah I was planning on trying tie it back further out the way if the wheel spacers weren't going to be enough.
Conedaddy
