engine dieing??????????? need help!!!
young_2010_chris
alright so today i was drivin down the road mindin my own business and my motor jus dies didnt sputter or nothin and i had a quarter tank never done it before so i stopped and it fired right up allright good but weird i get about 8 miles down the road then it ******* did it again ok started rite back up keep in mind it doesnt sputter wen it dies..so i was drivin some more and then it does it again this time it cranks and cranks and tries to start but jus wont do it so i left the key on and went to the fuel rail under the hood and hit the release valve and it had pressure so it still cranked and cranked so i was stranded for about an hour then i decide to try to start it again and it fires right up so i went to the gas station and put 91 octane and i drove it 60 miles and didnt do it again so my ? is is it the fuel pump but in past experiences they jus quit and dont work again so give me some info guys thanks!!!
branndon_b
Lake Charles, LA
i know in my '99 yukon if i get much under a 1/4 tank it'll start dying at stop lights/signs and stuff. it'll start back up, but it's time for me to get to a gas station. i'd try to keep it above a 1/4 tank and see if the problems go away or if it still does it. i've found my gas gauge a decent "suggestion" but not necessarily the absolute truth about how much gas i have. go for the easy fix and just keep more gas in it and see if that helps first.
fyremanpat
Fyremanpat
fuel pump!..mine did the same thing. is it whining when you turn the key to on? or can you at least hear it when you do so?
HotCarl
ID/WA
Dang 118k? I remember the stocker on mine went out in the 80-90k era.
ravingmadman
Chief Knuckle Buster
Greater Seattle
Add me to the fuel pump camp. Just because you have pressure, doesn't mean it's enough pressure. :) I did the write-up, PM me if you have any questions when you do it, it goes directly into my email, which goes directly into my droid. Have fun!!!
:drunk:
992dr
Eastern N.C.
Mine did the same exact thing a few weeks ago.
I replaced my fuel pump about a year and a half. The new has always had a loud whine.
Did yours throw a code?
Mine threw P0452 = evap emissions control system pressure sensor.
What fuel pumps are you guys using?
young_2010_chris
young_2010_chris
n ope jus o2 sensors
992dr
Eastern N.C.
Started mine yesterday for the first time in a few weeks and it has thrown a couple of codes.
PO141 O2 sensor heater circut malfunction bank 1 sensor 2
and PO452 (again)
Any ideas what they are?
young_2010_chris
young_2010_chris
and PO452 (again)
o2 codes wonts cause it i jus got my pump in and runs fine now
destroyer1362
A work in progress
Midlothian, TX
I'd replace the relay first then the pump if that doesn't work. Don't forget to use ACDelco parts, so I'm told.
TheBeast99
i'd definitely say the OP's fuel pump is on the way out. get that shit replaced asap. and ya, they whine like hell when on the way out.
and with the new pump, just to make it last long, don't let your gas drop below 1/4th, just cuz it's the gas that keeps the pump in shape :)
CrackerJack135
