Dash panel
THE DONALD
Hi guys
I own a 2011 LTZ.I need to remove The plastic panel that lies between the dashboard speaker and front window. It includes the front defroster vent and the solar sensor and runs across the whole width of the windshield. I need to remove it in order to glue it back together it has cracked in several pieces. It has popped off in several areas but I don’t know how to remove it completely and don’t wanna crack it any further. Any tips on how to remove it? Thank you in advance.
Any repair tips would be greatly appreciate it also
St. Louis
Yes, remove A pillars from both sides. Driver side has 1 bolt under a cover and passenger side has 2, one on each leg of the handle under a cover.
as noted pull the pillar covers and then it just unclips, you will need to untwist the sunsensor out in the center (the little plastic bubble)
t_bergman
Chicago
Does anyone know the GM part number for this piece???
Depends on your interior, if you have the ebony interior the part can be had here: https://www.amazon.com/dp/B08K1J6Y5M?psc=1&ref=ppx_yo2ov_dt_b_product_details
This is GM part number 23224733, it runs ~$420 at the dealer if you want OEM. This doorman part linked above is the exact part I just installed into my 2013 Yukon XL SLT, you can see pictures at https://www.tahoeyukonforum.com/threads/dashskin-removal-dashboard-replacement.135939/.
dizhai
