Rooftop cargo box bounce
optimusprime
2008 yukon Denali xl with the factory roof rails that came with it. Picked up a Thule Force XT Cargo box. It’s the big one. When we drive down the road, it bounces up and down quite a bit to the point where it contacts the roof. This is with and without cargo in the box. Seems like it’s the roof rails flexing. Is this normal? Does anyone else have this issue and is there a fix for it?
Geotrash
Dave
Richmond, VA
I've run a large Thule box on mine and yes, the factory bars will flex, but it should still be plenty stable to keep your box in check. My hypothesis is that the nose of your box is right at the point where the airflow will keep splitting above or below it as the bars flex, increasing the amplitude of the flex as it goes. My advice would be to play around with moving the box forward and back - either by sliding the box on its mounts, or by sliding the bars themselves backward and forward, whichever is easier, to find a point where it doesn't do that any more.
O
optimusprime
Did you find by moving it more rearward that the bounce was reduced?
Geotrash
Dave
Richmond, VA
Mine was fairly long, so moving it back any further would've caused interference with the liftgate. I had to move mine forward so that the nose overhung the sunroof by a little bit:
O
optimusprime
Im wondering if it’s the factory bars that are the issue. Met a guy at the store who had the same box and his was mounted on a Subaru and the box was solid as a rock. His rails were thicker than mine.
Geotrash
Dave
Richmond, VA
It will make it more solid, but still won't resolve the aerodynamic effect that's causing it. It's known as aeroelastic flutter:
Moving the box forward or rearward will change the way the airflow over the front of the vehicle and windshield hits the shape of the box and should be enough to eliminate the problem. Moving more weight to the front of the box will also help.
O
optimusprime
It’s definitely not over limit. When I push on the box while the vehicle is stationary, the box wobbles like a spring board. It is firmly attached to the rails but the rails appear to have a TON of flex in them. The guy at the store had rails that didn’t budge at all.
Geotrash
Dave
Richmond, VA
One side of the box needs to be as close as you can get it to the side rails. That will reduce the flex about as much as it can go. I've offered you all of the guidance I can for the factory bars. Sounds like you’ll be happier with aftermarket bars. Good luck.
O
optimusprime
Thank you for the help. I’ll give those tips a try and see if it helps. Much appreciated!
wjburken
Eastern Iowa
For what’s it worth, we have a Thule Evolution XL and have had this issue. I had the rear bar as far back as possible and tried to balance the load as much as possible but still had a tapping on the roof on our first and only trip with it. Had it on our 2008 XL Denali. My resolution was to again readjust the contents best I could and then I ended up buying some micro fiber towels and some gorilla tape at a Flying J and made a pad on the bottom at the rear of the carrier and that took care of the tapping sound. Haven’t had to use the carrier since so haven’t looked for a more permanent solution.
O
optimusprime
Figured I’d follow up with the solution. I couldn’t get the box to stop bouncing. In fact it was near hazardous going freeway speeds with the factory bars. Picked up the Yakima Slyline bars and now the box is rock solid even at freeway speeds.
vsaravia
