89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Put 140mi on her yesterday.
Drove up to a easy little hike in the mountains, then did some off-roading nearby, finish the day off with the only meal I ate yesterday at yard house for dinner.
I wish we had places like that around here to get lost on and get away form the BS.
Thinking this might be the way to go at least it's off to one side a bit
RooTBeeRthe1st
Thinking this might be the way to go at least it's off to one side a bitView attachment 368903View attachment 368904
Unfortunately, I'm pretty sure I put mine right where Whipple says to put their intercooler radiator... Which means I'll have to move it somewhere else because I'm not going to stack a big trans cooler, intercooler, condenser, and then finally radiator.
Geotrash
Dave
Richmond, VA
I ended up having to move it right a little because of the connectors, made a bracket and some slot's in the lower plastic, better than dead center I guess, will find out next time I head for the mountains how it works with the cold caseView attachment 368937View attachment 368938View attachment 368939
You'll be fine unless you're towing a camper. I still have the Tru-Cool mounted ahead of the radiator in the 2007 and it only heats up the coolant when I tow.
Geotrash
Dave
Richmond, VA
a regular radiator or is it a bigger one?
The 2007 has a a factory radiator, but I had the Cold Case in my 2012 when I still had the Tru-Cool mounted in front of it for a little while, and I couldn't keep that cool when towing heavy in the heat either. The only solution I found that worked for the 6.2 was to run the cooler below the bumper.
I picked up a ac cooler fan out of a 80's or 90's pickup at the junkyard, it's a pusher fan if I have to I can mount that in there somewhere and hook a switch to it.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
I’ve been getting an average of 12mpg e85. I changed my tune to 89/91 BBP tune and on the way to the airport I was getting 18mpg, we’ll have to see what the average turns out to be over time but so far I’m a fan. Lol
I was thinking about the higher octane tune on E85 too. Will be watching for your report.
RooTBeeRthe1st
I get about 50mi less per tank on e85.
While parts shopping the last week or whatever, I started thinking that my oil consumption could definitely be partly due to last summer when the radiator blew up and I overheated the engine, so now if I'm taking everything apart anyway, I should probably just actually rebuild it in case cylinders are slightly out of shape and or something else has an issue and needs to be machined before I throw a bunch of nice parts in a bold block...
Unfortunately that means the job will take a lot longer if I have to send stuff out to a machine shop.
define overheated, as in how much did it over heat and for how long?
if it only happened once and you noticed the problem right away and pulled over stopped and shut it off, then you are fine
if you drove it and never noticed any problem and it gave you a warning on the dic and you then pulled over and stopped, then you are probably fine as well
if it overheated and you continued to drive it and it made any weird knocking sounds and was over the red line for a while and or noticed a big drop in power, then it's possible you damaged something.
or if it overheated several times and you continued to drive it anyway like a stop-n-go when it cools off kind of thing then it also possible you damaged something.
RooTBeeRthe1st
Couple miles no coolant.
I knew it was hot, but hoped there was still something in the system.
Whatever air was against the temp sensor was reading like 280.
This was last summer, I've put probably 10,000 miles on it since then, the only issue I've noticed is that higher oil consumption.
I'm starting to get a ticking noise but that's only come in the last couple months, and I'm honestly not sure if it's the dod lifters, potentially worn out lifter buckets, or just an exhaust leak.
well that's probably going to have to be a personal call on that one, I haven't driven that far with no coolant since I had my 1st car lol I drove that one to the levy so to say, melted 2 sets of spark plug wires and it was puff the magic dragon at 10 15mph max in the end, young and dumb...... lesson learned
oh ya and i got arrested in it and it got towed away... in the bitter end long story...
RooTBeeRthe1st
well that's probably going to have to a personal call on that one, I haven't driven that far with no coolant since I had my 1st car lol I drove that one to the levy so to say, melted 2 sets of spark plug wires and it was puff the magic dragon at 10 15mph max in the end, young and dumb...... lesson learned
Literally the only issue of noticed, besides the elevated oil consumption, is that either exhaust leak or valve train noise, and the exhaust leak is completely unrelated if that's what it is, and the valve pick, has slowly been getting worse over time and didn't happen until maybe 6 months after it overheated when I noticed, so likely also unrelated.
I'll probably just measure the bore both directions down every cylinder in the top middle and bottom just to check for uniformity and make sure that's not an issue, just trying to save down time when I rip it all apart.
ScottS-Michigan
