On my 2007 (4WD), the best I could ever get on vacations was like 15.5 mpg. On my 2013 (2WD), I was getting 18 mpg. Now with the Denali ('17, 4wd) I am getting 17 mpg around town and 20+ on the hwy.
MassHoe04
Western MA
This depends a lot on the State and the insurance policy. I have full glass coverage and don't pay a dime for a windshield on either the truck or the car. And my rates don't go up when I have windshields replaced. Yes, I'm sure that I pay for that, but peace of mind.
Same in MA. No out of pocket, but we pay.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
That's exactly what I get on highway trips in our XL Denalis. And if I floor it just once to execute a pass, it'll drop my trip MPG by a half a point. Lol.
The best way I have found to gain MPG points is to coast to the stops from a distance as often as possible. I have perfected that on my daily drive.
Liking that torquey motor? :)
Yes!!! So smooth and effortless. Cannot wait to get exhaust and tune done. There’s a shop here locally that has a good reputation that I’ll take it to for tuning and hopefully I can just stand there while they dyno tune. Hopefully do that before summer travels start
St. Louis
So I have one TPMS sensor that stopped working on the Acadia. I have the tool to relearn them and tried to do a relearn but that one sensor doesn't respond.
I called a local tire shop asking if I could just drop off the wheel and have the sensor replaced and they want $85.
Seems kind of pricey or is that about a normal fee to break the bead on 1 side and replace the sensor?
I was quoted $20 per tire if I supplied the sensor.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
How hard would that be to break the bead on a 20" wheel?
You got a hitch? Lay it on the ground under it and use a jack to break it. You do it from the road side of the wheel. Remove the valve core first to let all the air out and help it vent better. Use a 2x4 to hold/wedge the tire bead open and use a knife to cut the old valve stem. Lube up the new one and pull it through. You will need a valve tool that threads onto the stem so you can get enough pulling/prying force on it to pop it into place. And don't drop anything in the tire in the process. It's a skills test but I've done it a few times.
St. Louis
So would any snap-in style 315mhz sensor work?
Geotrash
Dave
Richmond, VA
I learn something new here every day. Thanks!
ScottS-Michigan
