Chasing Code issues 2015 Tahoe (P0430 and Tighten Gas Cap)
bonedog
I am intermittently getting the codes/messages noted above. I've already replaced the O2 sensor on the right side as noted (I know there's two of them), but I'm wondering if anyone's had experience with both of these popping up on your vehicle and a solution for it? Gas cap is always tight and it doesn't matter where the gas was bought from, how full the tank is, etc.
Never seems to effect the way it's running, idling, etc.
If there's a test that can be done, please post a link/details to it. My nephew is a tech for Mercedes and can do what I need him to but I need to "feed him" the info (don't get me started...).
Thank you!
Rygrego
Topock, Arizona
Yes, well, "Tighten Gas Cap" isn't a code, you're right about that. One could call it a description of an evap code, no?
Not trying to be a smart ass , but the only reason to check a gas cap would be for an evap code, it would not change the code mentioned. There is no evap code present. The code mentioned is for a catalytic system below efficiency threshold. The picture of the scan tool states one code and says nothing about a gas cap. I get the impression the author said he tightened the gas cap because that is what everyone does when a check engine light comes on just in case. Replacing the cap would be a waste of money in the absence of an evap leak code.
Thank you!
P0430 is for a bad cat on the passenger side. It does not mean you have a bad O2 sensor, lifter, bad taste in music, just a bad cat.
I would ask myself, why did the cat go bad?
From the previous generation's shop manual:
Circuit/System Testing
  1. Inspect for the following conditions, which may cause a catalytic converter to degrade:
  • An engine misfire
  • High engine oil or high coolant consumption
  • Retarded spark timing
  • A weak or poor spark
  • A lean fuel mixture
  • A rich fuel mixture
  • A damaged oxygen sensor or wiring harness
  • The catalyst test may abort if the vehicle falls outside the conditions for running the DTC.
  • A catalyst may be temporarily degraded if a fuel with high sulfur content has been used. Drive the vehicle at highway speeds for 10 minutes and retest the converter.
  1. Inspect the catalytic converter for the following conditions:
  • Dents
  • A severe discoloration caused by excessive temperatures
  • Road damage
  • An internal rattle caused by damaged catalyst substrate
  • Restrictions
  • If a condition is found, replace the catalytic converter.
  1. Inspect the exhaust system for the following conditions:
  • Leaks
  • Physical damage
  • Loose or missing hardware
  • Restrictions
  • If a condition is found, repair the exhaust system.
  1. Inspect the post catalyst HO2S for the following conditions:
  • HO2S not at the correct torque.
  • Damage
  • If a condition is found, replace the post catalyst HO2S as necessary.
  1. If all physical conditions test normal, test or replace the catalytic converter.
Repair Instructions
Note: A new converter with less than 100 miles on it may set DTC P0420 or P0430 due to out-gassing of the internal matting. Operating the vehicle at highway speeds for approximately 1 hour may correct the condition.
Not trying to be a jerk, either, but it seems like you're picking nits. The OP stated he has multiple codes, he just didn't list them all. He showed one code (of three in the scanner) and wrote another code's description. @Tahoe14 appears to have responding to the code that was described. It's "bigger picture" stuff. Yes, I'm quite done now.
B
bonedog
Thanks all. For what it's worth, there's only 1 code that's thrown and the scanner has 3 pages that show/describe the code. The only code is P0430. The DIC will sometimes tell me to tighten gas cap, but there's no code that gets stored. But, for $6, I replaced the gas cap. Now...everyone can take that one off the potential culprit list.
The Check Engine Light hasn't been on for a week or so. It will come on, stay on for a week or so then it will randomly go off. I'm not adding gas, running low on gas, etc. when it happens so there's no pattern I can draw from that.
I do have 148k miles on the Tahoe and it started doing this at about 110k miles. I'd truly hate to think that my cat is, in fact, bad...but that's why I'm here asking the backyard mechanics.
B
bonedog
Update: replaced both O2 sensors on the passenger side. After driving for a bit, two codes were thrown: P014A and P0158. Just to test what's happening, I cleared the codes and the only one that's shown back up is P0158. That seems odd that a new electrical code would show with the OEM O2 sensor installed. Any suggestions?
As of now, my thoughts are to go back under and check the wiring/plug and make sure I got it on tight. Or remove the new sensor and put the old one back in. Note that the "old" sensor was only 6 months old...
swap the questionable 02 sensor to the other side and see if the code follows the sensor or remains in the same location
keep it simple
as for "tighten gas cap" technically that is a "small evap leak" regardless if it throws a code or not. if you replaced the gas cap with a oem cap and the message remains then you have some other evap leak, either one of the solenoids (usually the front one for a small leak) and/or rear one & the canister. if it is a issue it's usually cheaper, easier and faster to just shotgun it and replace all 3 and call it day.
I was under the impression the 15+ had no gas cap, my 18 does not.
B
bonedog
So...came home and took out the "new" O2 sensor from Rock Auto and put the old one back in. Codes are gone so i'm having Rock Auto refund the part.
Now.....I'm back to checking to see if the original Catalytic code comes back on. Here's hoping it was just the upstream O2 sensor...
B
bonedog
And I spoke too soon. P0158 code came back up repeatedly. I can’t tell any pins being bad in the harness connector but I can tell you it was a bear to originally separate the connector.
Anyone know what it takes to possibly replace the connector from the harness (not from the sensor)?
B
bonedog
It does not follow. Isolated to the one downstream bank on passenger side. Two sensors tried and both are good on driver side and both bad on passenger side.
then next up is a ohm test on the wiring harness, I am not sure what the specs should be but if you suspect the connector check one pin and then go up the wire harness a bit and probe the wire from the wire to the pin it should read zero on each side that will tell you if it's in the connector or not or if it's up higher somewhere, if nothing pans out there then check the harness ohm's and see if they match factory specs, maybe @swathdiver has that info.
I'm getting "Tighten gas cap" on some of my start ups on my 2015 Yukon. I haven't had a CEL or code.
Looks like I'll try and swap the gas cap and see if it fixes it.
THarber
I want to remember that the tighten gas cap message only reads when the tank is at 1/4 full. Also replace it with a GM cap, not china.
I think the OP is in early stages of a bad cat. When the truck is started up initially, it will read high voltage but then as the cat warms up, voltage should drop. You should see readings 0f .45 to .50 volts. If the volts do not change at all, its a wiring issue. You might even have a bad MAP sensor, vacuum leak of bad MAF.
Partially correct. The evap test is what triggers the leak code, and that test is done with the fuel tank level between 1/8 and 7/8 (some say 1/4 to 3/4, but you get the idea). There are other conditions like the ambient temp vs the coolant temp (must be within x°) so typically on a cold start.
Drewphil
