2024 Yukon Refresh Spied (warning- it’s not that exciting of an article!)
terptahoe
Not sure if anybody caught this. I’m interested to see what the 2024 has to bring. At this rate my 22 order might become a ‘23 and nothing I hate more than getting the year just prior to a refresh or remodel. If you can hold out like 18ish months from now could be worth it.
My bet is the refreshed Sierra/Silverado interior makes it to the Tahoes/Yukons and probably a lot more tech (ie super cruise). That new interior would be a welcome change to those with Tahoes or non Denali Yukons. Not that the current version is bad by any means just a touch bland and falling behind the Expedition and sequoia refreshes.
What would you all like to see most in a refresh?
Banks22
Michigan
I have a 21 Tahoe, I know the 22’s have a designated button for camera view which I would like. Fog lights would be nice. My only other dislike is not being able to access the RSE on the front screen. If it’s Parked u should be able to access rear screen. I take my kid to school and she has to have tv on so I have to back out of garage to get a signal then get out open her door load the screen pick a cartoon and go. That’s my main dislike. Other than that love the Tahoe, get lots compliments.
Banks22
Michigan
What’s also interesting is the sales comparison to the 2020 model year amid all the shortages.
SSGUNNER
Yep i saw that. Its interesting how it turns out given the previous gens only have a 5yr cycle before a new gen come out. Changes may be minimal, perhaps more trims?
StephenPT
St. Helens, OR
Looking at the new 13.4” center screen in the Silverado/Sierra redesign it looks like it would be too wide to still work with the push button shifter. That would mean column shifter makes a comeback (doubtful) or center console gets redesigned to have a handle or push button shifter.
I’d be surprised they revamp the dash so quickly…
Steebu
Well, given all the teething problems the 21s had, that 18 month wait might be longer if you wait for a 25. :)
I’m really curious to see what the 23s bring to the table - and honestly, if it’s just big fixes and functional RSE I’d be happy with that.
Now that said - any existing owners of 20’s have any thoughts? Are they relatively bulletproof compared to the 15’s? Could we expect the same from the 23s?
GMCnewbee
Well, as long as you are asking I do have a couple of thoughts. I am not complaining about my 2022 Denali ride quality, it is great. But, I wish the rear suspension had more ground clearance and a better "look". I am thinking about going with 4WD in the future and it just looks like there could be more clearance engineered into the setup. Also, on the "minor" front. The chrome trim on the AC outlets shows up on our rear view mirrors as a slash across the mirror. Not a big deal until you see it, then you can't unsee it.
Wwes
I'd wait just for the column shifter to return, although I fear it would be an eternal wait.
I'm too concerned about the rear lower control arms. We have a lot of sand roads where I live, sometimes deep sand. Last thing I want is another piece dragging and making it even more likely to get stuck.
DenaliCountry
Agreed on this. I actually feel like the new screen looks a little fisher price to me compare to the current yukon denali dash. I personally like the '22 dash and hope they leave it as is for now.
Ketzer
Not a fan of the new side glass design... although that is the current trend with all the manufacturers.
NYisles1
The Build and Price is up now for the revised '22 Silverado/Sierra on Chevy and GMC sites. You can really see detail on that new interior. It is a big leap in design. Something at least that nice is likely coming to the SUVs for '24 models.
Reddevil96
Chandler, AZ
you can add the button from a 22 and it will work. I already did the leg work to confirm the wiring is in place and the circuit works as designed. You will have to look up a Stability Control Switch with all your RPO code, then add the RPO code UV2 to get the correct part number
Banks22
Michigan
Wow! Ok I’ll have to look into this, I’m not sure if there are any open switches, or where the switch is located on the 22’s
Cryptocap
Here it is on the 22’s.
d_hawk
I have to credit this info to peterlawl84 on another forum. Based on his information I ordered the replacement switch panel to add the 360 degree camera button to my 2021 High Country Suburban. If time permits this weekend I will install and report back.
Banks22
Michigan
d_hawk
Do u have a link to where u ordered this online? Having trouble searching that
It appears you need the same part that I used… 84786497
I googled that part number and ended up ordering online from quirkparts.com The part arrived today, about 10 working days after I placed the order. I called my local Chevy dealer and they quoted 2 weeks to get the part in and we’re about $15-20 more that the above website I used even with shipping included.
Banks22
Michigan
Awesome got it. Yea I didn’t get my door codes but reading what u put and adding x88 I figured it was the same part. I’m gona double check in morning and then order. Let me know how install goes if it’s just plug and play. May wana disconnect black battery cable before u unplug switch?
CrackerJack135
