anyone use "rodneysboxes" enclosures?
steve671
CA Bay Area
I am considering one of these for my 2010 PPV and was wondering if anyone has used anything from these guys and how it went??
I have that 10" box in my Silverado with a JL sub and Soundstream amp. Does real good considering the cubic inches available. I'm happy. It fits perfectly in the space inside the console. Easy to install, it doesn't even need to be screwed down, the console holds it in place tightly although i did put a couple screws from under the cupholder into the box.
S
steve671
CA Bay Area
Cool, thanks for the input. Is there space left inside the console for an amp, or did you mount your amp somewhere else?
No, there’s zero room left in the console, he utilizes every cubic inch possible for the box and even at that, it’s at the minimum needed for most 10’s. I mounted my amp under the driver seat.
Edit: I suppose you could use the storage area under the lid but I didn’t want to lose that space. The box goes under the cup holder area and all the way forward from there, the storage area doesn’t need to be altered. Under the seat was the logical choice for me.
S
steve671
CA Bay Area
Got it, thank you.
bobo49505
I have one of the 8" boxes it sounds great i put my amp where the bose amp went it was a tight fit but it fit.
Andy123
Yesterday I installed a Rodney box in my 2011 Yukon w/ Bose Audio and a new Boss Head Unit. I did run into a snag that I am hoping someone else has overcome...
Installed:
>Boss Head Unit
>RP5-GM31 Wiring Interface
>12" Alpine Sub w/ Sound Ordinance Amp (sub amp only)
My intention is to keep all the speakers running on the factory Bose Amp. The speakers all played when I did the test fit and systems check before re-assembling the console and dashboard, however, when I buttoned everything up and reconnected the new amp for the sub I lost all my speaker sound.
Based on what I read on the Chevrolet Forum, it sounds like the amp went into limp mode or a state of confusion because I disconnected the factory Bose sub. Here's the question: should I connect the + / - wires from the Bose sub to complete the circuit in hope that the complete circuit will satisfy the Bose amp and it will continue to provide sound to the speakers? Or should I add a type of resistor in the + / - amp wires and complete the circuit that way?
Thank you in advance!
Installed:
>Boss Head Unit
Do not connect the old sub speaker wires together or you’ll fry the factory amp. What happens if you disconnect the new sub and amp? I’m not familiar with the interface you used. How did you wire the new sub and amp into that interface? Is it specifically designed to run an aftermarket amp?
Shackman7878
San Bernardino
I will be installing both tomorrow the 11 inch console box was tight putting the speaker in.
Also Bought the 12 inch between captains chair one the hole is a little big have to check and recheck the screw will hit wood and not openness.
If you want to run a factory radio but want a aftermarket Sub and amp you can run one of these
RCA Line High Low Level Amplifier Converter - Random one I found on amazon.
What do you mean it was tight? Did you use the info Rodney provides ? You shouldn’t just use any sub, you need to look at the overall depth of the sub and recommended cubic inch minimum for a sealed enclosure to match sub to box. If you get the wrong speaker it’s not going to sound great.
Shackman7878
San Bernardino
Tight meaning it was not hitting the bottom of the box but around the hole itself had to sand it down in couple spots for it to almost drop in.
The one I bought is close to the Kicker listed in the ad - (not the 12 inch listed in one of the photos)
Andy123
I wired the new sub amp RCAs and remote wire to directly to Boss Head Unit output, the Interface is used to retain the factory amp and steering wheel controls. So the new sub and amp both work. It is design for an aftermarket amp, I bought everything from Crutchfield so I will call in to their customer support, the online techs are really helpful maybe they've seen this before.
If not the open Base sub wires, maybe the interface is causing the factory amp to quit. I will dig in a little more try and rule out the interface as the culprit and post back
Yeah check with Crutchfield. You might have to wire in a resistor in place of the factory sub. I would think the harness would account for this but you might have to do something else.
Shackman7878
San Bernardino
Got the box installed Had to use a rubber hammer to fit the front part in also had to trim part of the lower console for it to fit. Be warn it is a very snug fit. Waiting on 2 amps to show up.
It’s meant to be a tight fit so it doesn’t rattle. You don’t even need to screw it down. The console holds it tight.
Shackman7878
San Bernardino
Did not screw it down once the seats went it I could not move it might pull it later if it rattles and put foam around all the metal contact points.
brice715
