Current Constraints
cgator67
I would not bank on all future HDMI devices being compatible with current HDMI standards. At some point, the hardware just will not support it. I'm by no means an expert on HDMI, just using logic that applies to pretty much all technology. I had a 10 year old Macbook Pro that I finally had to upgrade because it did not support the latest software.
I'm not arguing this is some immediate problem either, just that it will eventually be one and unlikely cheap to fix. Whereas a new tablet is quick and cheap swap.
HDMI has been around for almost 20 years already. Yes the spec has been updated and there are certain features like eARC that require a newer standard than from years ago. But most HDMI devices are backwards compatible at least when it comes to basic features. And just playing HD video from a newer device shouldn't be an issue even 10 or 15 years from now. And I doubt I'll still have the vehicle beyond that timeframe. There's a lot more about the vehicle I would worry about becoming obsolete before the HDMI ports...
selectsplat
On the topic of constraints...
Ordered 11/12 and was delivered to the dealer last night. However, they are missing the 22" black wheels and is showing 2 more weeks for those to be delivered. They are calling around to see if any other dealer has them and will work it out with them if they can find them.
In hind sight, I wish I would have ordered with the standard wheels and bought the 22" aftermarket. Factory installed is almost $3k but you can buy everything for $2435 + tax. Leaves about $400 for install in my neck of the woods. Plus I would have the factory wheels to sell. Lesson learned I suppose.
That’s exactly how I ordered, standard 22” for nothing additional, and will by 22” aftermarket.
Also ordered on the same day as you, but I’m holding out for the 6.2 and Liz package. Will probably end up waiting a couple more months.
Enjoy your new ride.
Oaktree
good to know on the black wheels, I tried to order them on my build but they won’t allow it with the six piston brembos.
cgator67
In my opinion, RSE is already obsolete. Even in the '21s it wasn't compatible with Apple Airplay. From my understanding the '22 doesn't have any wireless video option. My biggest beef with the RSE system is the integration. If GM's master plan is to have supply a dumb screen that requires an HDMI input for everything, why on earth did they put the inputs where they are most likely to be stepped on and broken? Why not bury them INSIDE on the center console where they could be protected? Or at minimum put an A/V cubby that can be accessed from the rear of the console and closed off behind a panel. It would need to be big enough to house some streaming sticks and their power supplies.
That said, I talked to Laura GMC yesterday asking when I could get an ultimate on order and was told to try again in a few months. He made it sound like nearly everything was on constraint. Adaptive Cruise control, air ride suspension, max trailering, power running boards, etc.
Agree the implementation could have been better with ports inside console, etc. But the Roku Express 4K+ gives me all the options I care to have, including Airplay.. It's not on the floor to get stepped on-- it's mounted to the side of the console. I ordered a short cable to power it so no cables are hanging. My young kids can't kick the ports on the center console from the captain's chairs. When they are older and can actually kick them, I hope they know better...
Could the RSE have been done better? No doubt. But I'm still glad we got one with it, at least at this point. Everyone should be aware of the design and it's pros and cons and make their decision accordingly.
When I removed RSE it came down to $2,000. I can buy my kids 2 new iPad pros, or a new iMac, etc which will be used way more than the 10 days we spend in the car per year that we’d allow them to use the screens. We don’t use screens as a babysitter, only on 2+ hr road trips. To each his own in this regard.
Yes, pure value for what you get-- two 12.6" blank TV screens for $2,000 is definitely more than it should be. But you can pretty much make that same argument about the vehicles themselves and most of the options being overpriced. At $71k with no screens, or $73k with screens, is it really much of a difference? It depends what you want in the vehicle.. to each their own, indeed.
GoHeels
Fair point regarding backward compatibility of HDMI. However, what about if HDMI is replaced by something better? Sure, this isn’t a home theater but the same applies. Just like those vans with TVs that only had composite video inputs… you either limit yourself to significantly outdated devices or you upgraded the entire system.
cgator67
Anything is possible but don't see it happening for a long, long time. And even when something new comes, it will be a long transition to the next technology where HDMI is still supported for many years.
bonedog
Unsolicited update from my dealer in Dallas today:
"Just touching base. I was hoping GM would release more information about diesel engine production today but so far they have not. I wanted you to know that I have not forgotten to update you and will send over any information when I receive it. At this point it might be another week or two before they update things."
AJMBLAZER
Marine Corps
Paducah,KY
Ours is here!
Two weeks before Christmas it went from waiting to built and awaiting transport.
Yesterday the salesguy called and said it was there. Cleared our schedule and we are picking it up now.
Ours is here!
Looks good! That’s the same color we ordered. Did you get the slate walnut interior? Enjoy your Yukon!
cgator67
Ours is here!
Looks sweet, enjoy it!
SFLOY001
Ours is here!
Same wheels i ordered
AJMBLAZER
Marine Corps
Paducah,KY
Yep. Slate Walnut. The GMC website doesn’t do it justice. Much nicer (to us) than the black we had before.
Thanks! We are so far.
We actually ordered different wheels on accident but those were on back order so they substituted these. Worked out for us.
R
Randy2876
I started searching dealers all over as I learned RSE (and now apparently the RST trim and the 6.2L V8 Sports package) are all on constraint. I got super lucky and found a dealer in Indiana that had one on the lot, not even in transit. I paid sticker price, $225 dealer/title fee, and paid $1,400 to have it shipped to me in South Florida in an enclosed trailer.
The shipping cost was a little higher than expected but I was ok paying it since they weren't charging over sticker and minimal dealer fees. Also, was able to use my Costco $1,000 rebate certificate, which is going away 1/3/22. So that took care of most of the shipping cost.
It took longer to ship out than expected-- paperwork was done by Dec. 13th but finding an enclosed trailer was apparently a bit of trouble. But the Tahoe was finally picked up from the dealer on the 23rd and was delivered to me on Christmas day, which was an awesome surprise. Another great thing about this one-- no auto start/stop! So happy this search is finally over... Unbelievable the times we are living in..
Some of you looking to order options currently on constraint may want to consider searching outside your local area and traveling to get it or shipping it like I did.
All of the options included in this build are the sports performance package, luxury package, panoramic sunroof, rear seat media, and second row bucket seats. Pics attached.
View attachment 358977View attachment 358976View attachment 358974View attachment 358975
Very nice, congratulations!
GTPace500
Hi All- new to the forums, and trying to purchase a Tahoe '22 Premier 6.2, but have a couple questions regarding the ordering process. I've been following along in this thread and read through every post, but confused about the following:
1) Went to a larger dealer in my area that typically has larger inventory and more allocations for vehicles than other chevy dealers.
2) I submitted the following build (https://bit.ly/3rf0whN) to the dealer in person and received a PO for the build - placed a $1k deposit. Dealer is not charging any premium, aside from $750 over msrp.
3) Because of this thread, I recently found out that the Tahoe Premier has a constraint until around March 22. So I called the dealership and they weren't aware until I brought it up with them. They stated, however, that the order 'never went through' because of that constraint.
My question: Are orders still "submitted" to Chevy, and just not accepted because the constraint? Or, did the dealer not "submit the order to Chevy" and just now found out about the constraint?
What I would like to do is obtain an order number from them so I can check up with Chevy on my own - directly - instead of hassling the dealership, but also want to ensure an order is submitted so that it could eventually be accepted when the constraint is lifted. Also, on that note, I think I recently read that while heated steering wheels (and for some vehicles heated/cooled seats) have been deleted for now, Chevy is planning a retrofit for those whereas they were previously not planning. Can anyone confirm that accuracy?
Any thoughts? - Thanks in advance.
AJMBLAZER
Marine Corps
Paducah,KY
My wife's Yukon has a dummy blank on the steering wheel in place of the steering wheel heating button. They told us when the parts are available we will get a letter saying to schedule a service appointment to have it installed for free.
Ketzer
Was at my local GMC dealer today attempting to order a 22 Denali XL. What he showed me that they would accept was no second row buckets and no front center console...?
Ugh ... so no power front console ... no buckets in 2nd row.
BadDaddy2003
