Fuel system help.... maybe
crammit442
I've done a bunch of searching and haven't found anything that sounds exactly like my situation. I got my '99 2wd 5.7 l from my grandmother when she passed away a few years ago. It initially ran fairly well, but was really only used to occasionally pull a lawn trailer. A year or two ago it became hard to start. The battery is strong, but if hasn't been started in a day or two it needs a squirt of starting fluid/fuel for the first start of the day. Once it starts it restarts fine until it's put away for a few days. The fuel pump relay tested good, but I replaced it anyway for good measure. I also replaced the fuel filter. I can hear the fuel pump cycle when the key is turned on. This hasn't been ideal, but I'm the only person that drives it and not very often so I've just lived with it this way. As of last weekend, it will start with a prime, but will only run for a few seconds. I replaced the fuel pump today (lots of fun) since I've seen people say their pump runs, but isn't delivering good pressure. I now have great fuel pressure, but it still only runs briefly. I can hear the system prime when the key is turned on and it will briefly run well, but falls on it's face and dies after a few seconds. I'm really a 3rd generation 4Runner guy and am not very Tahoe savvy. I'm not throwing in the towel, but I'm fresh out of good ideas. Thanks in advance for any suggestions.
Charles
exp500
You need some cheap and generic tools to find/fix 95% of the normal problems.
Spark tester, Fuel pressure guage, multimeter, test light, bluetooth scanner. Maybe $100. for all.
As a guess, I would first point to distributor cap. But it likely needs a full tune up. Plugs, wires cap/rotor, air cleaner.
Charles
I agree with what @exp500 said. To expand on the scanner, get one that'll show the live data from the sensors. You might have one that's far out of range and the ECM is just responding as programmed. For example: I had a '91 Blazer that got terrible mileage and kept fouling O2 sensors and, eventually, plugged the cat. Punching out the cat and replacing the O2 sensor ever so often kept it on the road. I was very young and didn't know any better. I worked at a mechanic shop, but, I was just a tire and lube monkey. Anyway, they let me try out their scan tool and I found the coolant temp sensor to be reporting some impossible temperature far below zero. It was keeping the engine constantly in warm-up mode. The ECM didn't know there was a problem and was just reacting accordingly.
I'm wondering if yours runs fine in open loop when the ECM is ignoring input from a few sensors and running on a base map. But, when it goes into closed loop, it then reacts to the erroneous input from a faulty sensor and alters the timing and/or fueling and dies.
Firing right up from a cold start then sputtering and dying after only a few seconds sounds like it's flooding itself. You might have a faulty injector (spider assembly) or leaking regulator. Have you tested the fuel pressure since installing the new pump? Aside from engine running pressure, you need to test the leak-down characteristics.
C
crammit442
Thanks for the responses. I have access to a cheap "Kobra" Bluetooth scanner, but I doubt it has anything more than the most basic features. As far as reading live sensor data, will there even be any data to read if it only runs 3-4 seconds at a time? I don't know if the BAFX Bluetooth scanner mentioned below will give live data or not. If not, any suggestions for a budget friendly scanner that will? I have lots of fuel pressure and volume at the schrader valve, but have not put a gauge on it or checked to see if it's holding pressure. I'll get a pressure gauge and find out. The distributor, rotor, and wires are AC Delco and only about 500 miles old. Fresh plugs as well. I haven't tested the fuel pressure regulator with a meter yet, but there is no leaking fuel at the vacuum line. I don't want to change parts just for fun, but the regulator is pretty cheap and easy to change. It's freezing outside and I don't have to drive it right now so I'll order a pressure gauge and better scanner from Amazon today and should be able to give more data in a couple of days. I don't know if this applies to my situation, but a buddy mentioned that some newer vehicles can lose their mapping if left off the battery too long. I disconnect the battery if Im not going to be using it for a few weeks. I've never heard of this before, but thought I'd throw it out there. Thanks again for the suggestions.
Charles
...will there even be any data to read if it only runs 3-4 seconds at a time?
This sounds kinda sounds like VATS (Vehicle Anti-Theft System) is killing it.
...a buddy mentioned that some newer vehicles can lose their mapping if left off the battery too long. I disconnect the battery if Im not going to be using it for a few weeks. I've never heard of this before, but thought I'd throw it out there. Thanks again for the suggestions.
Charles
After the ECM has been reset, it's common for them to stall once, maybe a couple times at most until it relearns idle. You just restart it and let it do its thing. It'll usually rev up, idle low, rev up, etc. until it relearns. This doesn't sound like what yours is doing.
Check this out: https://my.cardone.com/techdocs/pt 77-0011.pdf
C
crammit442
I'Ve seen the VATS mentioned. Most of the stuff I saw said that there would be a security warning light on the instrument panel. What you're saying does sound plausible. Edit: I didn't see the link to the document you posted. I'll have to try this tonight. It sounds EXACTLY like my situation. Thank you.
Charles
P.S. I'm going to feel pretty stupid if I crawled around under this thing Saturday dropping the tank and replacing the fuel pump. I'm glad I didn't go low rent and cut a access hole in the floor.
exp500
Your bluetooth may work. If using Torque app you need to use Torque pro and download GM PID's(other Apps similar)
When you get in truck, turn key to "on" and watch anti theft light. Self tests every time.
Next is turn key on, Wait for pump, off 3 times before you start it. If it starts nicely then usually fuel pump or fuel pump relay.
Also you can check codes key on not running. You do not want a P1345.
Good Luck and report back. These trucks easy.
C
crammit442
I wasn't able to get my Dad's scanner today, but I should be able to tomorrow. With the key on the anti theft light shows for a few seconds then turns off. When the key is first turned on the fuel pump also cycles. Turning the key on and off several times, the engine starts and runs well for about 3 seconds. Based on the VATS pdf, it looks like my truck is uses Passlock. I followed the VATS relearning procedure several times with no change. I replaced the relay just to be safe, but I don't believe it's bad because the fuel pump won't cycle unless the relay is in place. Reading everything I can find, it sounds like the Passlock module is a pretty common failure. I've watched a few videos on bypassing it, but most seem to be aimed at getting the anti theft light to turn off rather than fully bypassing the system. I see modules on eBay for $50-60, but want to be sure that's actually the problem before buying one. If the system can by tested with a meter I can check it that way. I don't have to drive it right now so I can scan codes before doing anything else. Any suggestions in the meantime? Thanks again for all the help.
Charles
C
crammit442
I haven't read the codes yet, but I spent (wasted) the whole evening watching YouTube videos and reading about the Passlock anti theft module/system. Totally down the rabbit hole. It may be something else, but the start and run perfect for 3 seconds symptoms sound exactly like what's going on. None of the bypass videos I've seen actually eliminate the Passlock module/system. Everything I've seen only works to make the computer "see" a key in the cylinder. I found bypasses for installing remote starters, but the Passlock module still has to be good. I don't have a "pill" or smart key, just the hall effect sensor in the key cylinder. There's a YouTube video from an eBay seller (100% positive feedback) that sells a rebuilt module w/a lifetime warranty for $150. There are others, but no warranty. Everything I've seen looks like getting a used one would probably just be buying time. I'm still going to read the codes before I do anything, but the seller looks on the up and up. I'll put links to the YouTube/eBay/website below. Anyone have any experience with this? If I decide to buy one I'm going to buy through eBay w/PayPal/visa for a little better protection. If this does turn out to be the problem I'll make a complete new thread for future reference. Thanks again for all the help so far.
Charles
exp500
Charles, Thanks for the update! Because of the "clutter" and no ability to easily and correctly search these forums it may be better to stay on this thead. Only start a new one if you resolve problem and create a sticky or Troubleshooting help post.
From what I have seen on VATS, the dash light flashing on momentarily and going out is the correct operation if theft is not active. Light would stay on if active. A Tech2 or similar hi end scanner would verify a theft shutdown or correct operation with the corresponding codes. Where do you live? several members here have Tech2's willing to help.
There is little info available for the internal workings of this system and UTube wont likely post "How to steal a Chevy".
There are 10+ posts here unsolved on no start similar to you.
I recommend you do some more diagnostics to "prove" this is your issue. Unplug the big connector on top of intake for F/I harness and verify pin connections were good/deep. Also noid light tests here- you can use a 194 bulb for a noid lite. The VATS injector shutdown shuts off the ground inside computer. So a bad engine/computer ground could be your cause, with some grounds under dash.
The factory manual is a big help here. Go here- you have to join to download-GMT400 CK Manual Project - The 1947 - Present Chevrolet & GMC Truck Message Board Network
Keep us updated! We are here to help.
C
crammit442
I'll only start a new thread if the issue is definitely resolved. One way or another, we're going to get to the bottom of this. From everything I've seen, I think you're right that the anti theft dash light flashing briefly and then going off is normal. When the key is first turned on the pump cycles. When it's turned off you can hear a bunch of short "clicks" right at the big connector on the intake. I actually did pull the connection and all pins and sockets were clean and dry. My Dad's going to run by my house in a little while and scan the codes. It's just an inexpensive Bluetooth scanner, but it may pick up something. I'll join download the factory service manual and check grounds also. I left a message with the company that rebuilds the Passlock modules. Hopefully they can give me some more specific tests to try. I'll keep updating this thread and please suggest anything else you think of. Thanks.
Charles
C
crammit442
Another hare brained thought. Im not sure how the entire Passlock system works, but the keyless entry is pretty sketchy with my truck. It's usually easier to just unlock the door with the key. Any chance security could "engage" because the system thinks the door was opened without disarming? The system doesn't chirp or flash the lights when when keyless entry is used. My system does not use a key with a pellet/chip.
Charles
C
crammit442
Small update. My Dad ran by and scanned the truck and there are no codes. The battery has been disconnected multiple times while doing the fuel pump so it may not throw any codes until it runs more than 3-4 seconds. A buddy of mine owns a car stereo shop and has had to use a key bypass many times to install remote start systems. I talked to him about it and his best guess is that the column/switch isn't detecting that the key has been turned. I'd still think it would show an anti theft light, but it's easy to bypass and reverse if that isn't the problem. Still haven't heard anything from the guy that sells rebuilt Passlock modules.
Charles
exp500
Charles- You may be onto the solution! Especially because Not having a chip key on a 99 and the way your remote acts..... Call your friend again and pick his brain about bypass install.... You may have one... resistor failing/ bad ground/ exc...
You could pull your column covers and see if fingers been in there.Also possible is broken wires from tilt. Good luck.
C
crammit442
I actually pulled everything to get to the module last night as well as the column covers. One of the YouTube Passlock videos I watched suggested grounding the purple wire to the module. It claims to fix it whether the module works or not. Everything was spotless so I don't think anyone's ever been in there. The truck only has about 114k miles. You don't have to cut the wire to expose the conductor so I didn't have much to lose. A bunch of comments on the video said it worked, but it didn't on mine. There are a bunch of videos showing bypassing just the ignition switch part of the system, but it doesn't fix a bad module. It's also easy so I'm going to try that tonight. Here's a link to the "no resistor bypass" video.
Charles
east302
Mississippi
Going by memory here, but I think the Passlock codes are B#### and may require a higher-end scanner to access. I use a knock-off tech2 on mine and know you can get them from it; I don’t think that they were in the same menu hierarchy as the regular P codes. If the Passlock is killing the injectors, it should store a code.
Technically, you’re supposed to clear the codes before trying the relearn, but here’s the procedure in case you don’t have it.
A quick fuel pressure check wouldn’t hurt (spec is 60-66 psi key on engine off) and it should hold within, say, five pounds for a few minutes after turning it off.
...Based on the VATS pdf, it looks like my truck is uses Passlock. I followed the VATS relearning procedure several times with no change.
I always thought PassLock was just the name of that particular version of GM's VATS. "VATS" is just the universal, all-encompassing term used for all of GM's anti-theft systems (PASSKey-1, PASSKey-2, PassLock I, PassLock II, etc.).
If you've ever considered getting this thing tuned, you could have VATS disabled as part of that. You might wanna look into that versus the cost of a replacement module. Get more bang for your buck.
Disabling VATS in the tune would allow the engine to run (assuming this is your problem). But, a fault with VATS might keep the "SECURITY" light illuminated on the cluster. You could just remove the light (LED?) or cut one of the legs if it's soldered to a PCB.
C
crammit442
I appreciate the information. I've read the relearn process, but not in that much detail. I've tried it several times with no success. I replaced the fuel pump Saturday so I think I have good fuel pressure, but I'll have a gauge Sunday. I'm starting to understand why none of these threads are ever fully resolved. This is like some crazy snipe hunt. Every time I think I'm on to something the plot twists and the hole gets deeper. I heard back from the guy that rebuilds Passlock modules and he said if it was bad the security light should stay on and mine doesn't. I found a new ignition cylinder that can be keyed to my existing keys, but after talking to them, apparently the cylinder only contains the magnet and the hall effect sensor is in the ignition lock housing. At this point I think I'm going to take a step back and figure out how to test everything else possible before just buying stuff. It's looking like it's actually pretty hard to fully eliminate or bypass the whole Passlock system. I laughed when I read about people actually scrapping otherwise healthy trucks because of this, but I'm starting to get it:cool:.
Charles
C
crammit442
This is all still pretty confusing to me. I'd never even heard of VATS before your post Monday. I think you're right that all the versions of VATS are sort of under the same umbrella. Even though my system (Passlock) doesn't use a chip or resistor key like PK/2,3, if I'm understanding it correctly, the system shuts off the fuel injectors until the ignition switch tells the system it's been turned has been turned by a real key. I saw that the system could be turned off in a tune. I don't actually need it tuned for what I do, but who are some recommended tuners and what does it typically cost? I guess before I look into that option I want to be sure my ignition switch is sending good key information to the rest of the system. Thankfully I don't have to drive it right now so I can afford to take a step back and do more testing before waste more money on things that may not be the problem. I really appreciate all the suggestions and feedback.
Charles
1948Buickroadie
