Cripped rear entertainment system on 2022 Yukom SLT
Edlee321
I received my 2022 Yukon SLT with rear entertainment package this week. (Ordered in August 3rd, delivered to dealership November 22nd)
The trucks interface completely changed to Google, and with that they removed critical features from the rear entertainment. They removed option for USB drive playback and miracast. I would like to know if they plan on bringing back these features in future android updates, right now it's running Android 10 June 2021 build date. There is an option to update software but this is the latest build.
I am using a USB drive attached to usb-c slot in the rear under the rear climate. It's the same USB drive that is working from my old 2017 Yukon, and I tested the drive on my galaxy s21 and it reads the files and plays videos fine, I need to know if there is a way to enable USB video playback, because using hdmi was not my plan for the rear. I wanted to be able to control the content with the front screen. And I'm very upset they crippled this option on the 2022 model year just to gain Google assistant interface.
kcb14214
I have the same issue, roku works great but my scandisk drive is useless. The usb c ports are just power right now… I even tried usb c to hdmi, no joy.
E
Edlee321
I was able to turn on developer options in settings and enabled usb debugging and will try using some adb commands, I am going to test which usb ports support usb drives, and then I'm going to force install some apps but that will not help me with the app the controls rear screens. Until GM adds usb file support to the rear app, I am p'ed off. I am most likely going to file a small claims suit against GM to get my money back for Rear Entertainment System.
kllerzomb
Overall the 2022 google "upgrade" is not that at all. The benefit of factory nav was having maps if you are outside of cell coverage. The rear seat experience is way worse between 2022 and 2021. It seems like a rushed deployment, and something that could be updated later, but you need a VEHICLE data plan now to have basic functionality. It won't even read your texts back without a data plan. It also wasn't advertised at all. The Chevy salesman I bought my Suburban from had no idea what functionality was included or excluded from the system.
E
Edlee321
I'm not happy about current state of rear seat entertainment, but I'm holding out hope for an OTA update for Android automotive OS will improve the rear entertainment app, this version google integration was definitely rushed, but android is completely capable of feature editions.
chris80
The RSE is very unimpressive. Currently using HDMI with Apple adapter AND lightening C for power. In a streaming world, I'm using 2 chords...SMH
R32driver
It seems so weird they would set up the system to work only with android and not iphone. Why not both systems like most aftermarket units? I'm totally lost if someone hands me a non iphone
E
Edlee321
No, it's not that the system isn't compatible with Apple or Android, the new operating system runs off of a special version of Android, which is very limited
ramanjot57
It is frustrating but it seems like an update will fix the streaming services but I don't think USB compatibility will be there even after the update.
E
Edlee321
How did you get to this screen, where it says streaming video unable to connect, you connected your phone to the back usb ports, and then what did you select on your phone?
ramanjot57
This screen comes on when you turn on the screen after getting into the vehicle. I connected the phone but the screen didn't even detect anything connected to it. I am a salesperson and apparently, nobody knows the fix to this at our dealership.
kcb14214
Hmm, on mine it just asks hdmi 1 or 2?
and ours has no hulu.
E
Edlee321
Nobody knows anything about this new system at the dealership I got the truck from too. I'm going to try adb on some apk's
bvs999
This will never happen, based on the 2022s running an Android, but I have seen the Fire TV interface in a 2022 Wagoneer and it seems great. I did not have much time to play around with it, but a system similar to the Wagoneer should be table stakes at the price point being charged for the RES.
Like many of you, I am hoping for an update to the system. Hopefully there are enough people that complain outside of the folks using message boards and we are not in our own echo chamber.
NYisles1
Agreed, that system in the Jeeps should be the bar. With GMs larger touchscreens that would be a great setup. Meantime, like you I'm hopeful for an update to bring access to some content.
Bhaliyo
Have you managed to get any apk on the rear entairtentment system?
Conedaddy
