2009 Tahoe ltz suspension
So I have my first Tahoe a 2009 with about 130k on it, the shocks are shot I plan on doing all 4 but am having trouble deciding on keeping the magneride set up or going with something like this https://www.1aauto.com/chevrolet-gm...AJDv8kkX4iTjernXw9AaRIlejgrGBX9saArflEALw_wcB Anyone have experience in this area? Thanks in advance
A 2009 LTZ Tahoe does not have Magneride. It has the Z55 Autoride suspension with G69 auto leveling. Check your RPO codes in your glovebox.
Others will chime in later with regards to which parts to use and whether or not those in the link are worthy.
Welcome to the Forum from NH.
Pics of the truck, please.
Do you plan to tow? The Z55 suspension (called electronic control suspension) is excellent for towing, as the rear shocks have air assist, which will automatically level the truck, whenever you tow or add significant weight (Home Depot run) on the rear cargo area. Replace the components once, and you'll be good for another 100,000+ miles on the suspension.
Michigantrails
Michigantrails
Roscommon Michigan
That is good to hear, thank you for the info, when I googled z55 on a Tahoe I kept seeing magneride so I just assumed that magneride and auto ride were the same, I have my build sheet and I have the z55 rpo along with g69 that says level control , auto air, hd
Michigantrails
Michigantrails
Roscommon Michigan
I will definitely be towing, I have a StarCraft islander boat and also tow atvs and occasionally a smaller car hauler. I definitely want to keep the auto level in the rear for towing. My rear shocks are blown out and I'm pretty sure my compressor is shot as well so I was thinking of that kit from trq I posted, but also don't want junk shocks
Michigantrails
Michigantrails
Roscommon Michigan
Also how would 22 inch factory rims fit/feel , I tried searching on here for similar questions but had no luck.I found a set of black factory rims on marketplace for a good price but was curious if there would be issues with mounting or if the ride quality would be worse with less rubber.
The Tahoe was made to run a 285-45-22 so they will fit. Lots of folks say a 22" wheel rides just as nice as a 20" wheel and others do not agree as it is really a subjective topic. I'm of mind that a smaller wheel will deliver a softer ride and certainly have more traction and be better off-road and for towing.
Lots of guys speak highly of the Dorman compressor even though most of us dislike most things Dorman! They also prefer the Arnott rear shocks with GM OE a close second. I do not have this setup so I'll leave it to Joe and the others that have it. Joe just put his back in commission after the previous owner disabled it.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Chiming in here as well. I have the same suspension and 22” whees on my burb. It rides a little harder than I would like but I have extra load tires which are overkill. If I had to do over I would have gone with Micheline tires on it.
I like the suspension and the auto leveling is great.
I vote to repair it and enjoy it.
Add the last 8 digits of your VIN, and @915_Tahoe may be able to give you the exact replacement part numbers for your truck (sometimes, part numbers change over time). Then, you can use those parrt numbers to find the best price on RockAuto.com, GMPartsGiant.com, or GMPartsDirect.com I used ACDelco parts for the rear air shocks, and a Dorman compressor (many folks on the Forum have used Dorman compressors with good results).
It is an easy DIY job.
Michigantrails
Michigantrails
Roscommon Michigan
Thanks for all the reply's, I really appreciate. I'll get the vin when I get out of work. Here's some pics of my new to me Tahoe 2009 ltz with 130k on it, so far I've replaced the headlights going toupgrade the drivers valve cover , got a tune to stop the afm, has a slight lifter tick that I'll be checking out when I do the valve cover.
dkreller
I am in the same boat as you. 2009 Tahoe LTZ. The last 8 of my VIN is 9R219430.
Looking to replace struts. Is it a good idea to replace the entire strut/coil spring/mount assembly all in one job?
I am in the same boat as the OP. 2009 Tahoe LTZ. The last 8 of my VIN is 9R219430.
My opinion is that if you have more than 100,000 miles on the current suspension, then you should replace everything (coils), once you make the decision to replace the shocks. That's just my opinion.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Front absorbers
Gm#19420493 $577.34 each
Rear absorbers
Gm#19368461 $589.27 each
91RS
GA
If you keep the Auto Ride, use ONLY factory shocks. Do not use aftermarket or reman. I’m in the minority here but nothing feels like the factory shocks do for Auto Ride. If you decide to delete it, use QUALITY parts like the coilover and rear shock setup Atomic Fab sells with Viking shocks or use Bilstein shocks. Suspension and tires are the absolute worst place to go cheap because it will ruin the way a vehicle drives.
pwtr02ss
Tennessee
I have the dorman compressor and it has a lifetime warranty, which I took advantage of after 5 years of use. The compressor was sounding lazy. I highly recommend it. I used the oem shocks and have about 80k on them. I recommend using oem shocks, simply because we seem to get well over 100k out of them.
Jumpshot12
