Max tire width, no lift/level
olyelr
olyelr
Elk Rapids, MI
These are two pics she sent me after leaving the tire shop.
CodyMaverick
I just put on 33x12.5 with no level or lift. Had to do a little bit of trimming to pull the liner back. It rubs a little still but not a big deal. Wheels are -12 offset.
olyelr
olyelr
Elk Rapids, MI
They definitely do not look too wide for the wheels or out of place. Looks legit like it could be an oem size to me.
eyebereej
Bay Area, CA
I love the way those look on your Tahoe High Country. You got me thinking about doing the same on my Yukon Denali. Mine has air ride though and its pretty active. Anyone out there know if 305/45r22 works on a 2021 Tahoe/Yukon with air ride without any rubbing?
H1Chester
What is the max tire width for the stock 20" wheels without rubbing? With spacer?
olyelr
olyelr
Elk Rapids, MI
Well, a 305 definitely worked in my case (with a 22” wheel, but that shouldn't matter). I think a 12.5” would be cutting it close for sure.
What do you mean by spacer…as in wheel spacer, or leveling spacer?
olyelr
olyelr
Elk Rapids, MI
The only issue I could see slight rubbing with is possibly when down in the lowest/parked mode. Otherwise it seems like the air ride models almost sit a bit higher for the most part, at least when driving.
H1Chester
Wheel spacer.
handstr
Thinking of going 305/55r20 thoughts ? Is that too tall for stock with air ride
olyelr
olyelr
Elk Rapids, MI
Not necessarily. But that will be nip tuckin’ it for sure. I would guess minor rubbing on the felt fender liner at most.
CASTLEDFW15
North TX
I am testing out the 275/50R/22 on my 22 Z71. Dealer installation. Tech said he would mount the two fronts, take it for a quick test drive with some turns of course. After that ride he will advise if there is any rubbing. If not, then he will install rear tires and call it a day. Some offset and tire size calculators seem to indicate negligible difference in width, height etc……says actual speed will be approximately .5 MPH UNDER Indicated. The wheels are a OEM replica set that was for my 21 Premier…….Same rim pattern just Black instead of Polished Aluminum. I am suspecting that even if the Z71 didn’t have a 22’ Option trims did. It is not like I am just making up a size. I don’t want any rubbing so if the 22” option doesn’t fit then back to the 20’s.
olyelr
olyelr
Elk Rapids, MI
Hmmmm, well that is factory oem size…why wouldn't they fit?
H1Chester
If you go with this setup please post in thread if you have any issues. My Z71 does not have adjustable air ride height.
curbud
