00-06 Tahoe MPG poll
What are you guys getting mpg wise these days (00-06)
  • Total voters
    30
Teamiez
now that these rigs are getting older and mileage is going up curious to see what the majority of people are experiencing MPG wise for some fun! I think mine was rated 14 city 17 highway and I am seeing a mixed average of pretty much 10-11 winter and 12-13 in the summer. Pure highway high 15’s
nick0789
2005 Z71, 186k miles; bone stock aside from upgrading to MSD wires during the last tune-up (@150k).
Around town I average 15 +/- 0.5 MPG
On the highway my MPG is dependent on the highway itself. If the speed limit is 55-60 mph I can get 19.5ish, with the addition of Lucas upper cylinder lubricant. If the speed limit is 65+mph I am lucky to see 17 MPG. Life can be rough at 2500+ RPM at these speeds, given the current gas prices lol
Chubbs
5.3L, lowest category. Mostly run E85 so it's expected to be less. But the oomph!
i drive a 2003 GMC yukon vin Z flex fuel and always curious about randomly fueling up on e85. i bought it used several years ago with a little under 100k and have no idea of what the original owner may have used.
are you to run the regular unleaded fuel nearly empty before gassing up on e85 and vice versa? what’s the harm in mixing fuels at 1/4 or 1/2 tank?
what negative side effects can i expect suddenly switching to e85 fuel?
of course i can read through the owners manual or do a web search (which i certainly will) but want to discuss with 1st hand replies. thanks!
There's no harm in switching fuels back and forth as long as it's FF compatible; your 2003 truck has a physical alcohol sensor that tells the ECM to adjust the fuel delivery. Your truck will use more fuel on E85 but should be a bit peppier. Higher percentages of ethanol can cause harder cold weather starts, if you're in that type of climate.
When you change your fuel composition significantly by refilling your tank, the ECU will sense the change if 3 gallons or more are added. What I've read is then it helps to drive it 7 miles without stopping the engine; that way the fuel trims are fully adjusted. That may not be your case since you have the physical sensor (the later models have a "virtual" sensor and may need that time to adjust), and I've noticed that mine adjusts within two or three miles.
And, of course, the amount of ethanol that you're getting from the pump can vary by station and season.
We often run mixes and get better fuel economy than straight gasoline and less cost per mile than full strength E85. My truck likes 16% to 22% or so.
This! ^^^^
TheAutumnWind
My 05 Escalade ESV AWD with a 200k mile LQ9 just averaged about 16mpg on a 10 hour trip to and from San Diego. I could probably get it to do 18 mpg highway in ideal conditions. Tends to do in the 11-12 mpg city. Not sure if you want me to skew your poll since its clearly not a tahoe.
Teamiez
Teamiez
Hey your 6.0L seems to get the same mpg as my 5.3L...still interesting to know. Only major highway trip I took with my Tahoe was from Buffalo NY to New Haven CT with 4 passengers loaded doing 70+ most of the way I saw a average of 15.8 lol
Redfire Metallic
My 03 4x4 Tahoe gets 12.5 city sometimes get it up to 13.5. Had another 03 2wd that would get 14-15 city. Had a 02 Yukon Denali that would get around 13.5 city. All of em bone stock, denali was on 22s, both tahoe on 20s
SnowDrifter
Sasquatch Country
Mine's all over the place. Depends on weather a lot too.
Highway going 75-80 in winter - 16-18
Same conditions during summer - 19-20
Highway going 60-65 - like 22-24
Same if I'm tailing a semi - 30 or so (Personal record over 60 miles was 36mpg with good weather and e0 gas)
In snow - 13-14
Suburban driving - 14-16
Rush hour - 13-15
Campus - 10-12
Mudsport96
40.923,-89.488. Illinois
Depends who is driving.
Me town/highway 15/19
Wife. Summer 12/18. Winter 4/7
So ill vote down the middle since her mpg offsets mine
Just did a round trip from Peoria il to Chicago and on the way idk what my tail wind was but got 21mpg at 85mpg going up but 12.5 was the best i could manage at 65 on the way back with the head wind lol.
MassHoe04
Western MA
I am in the middle group on the MPG poll.
13-15 city/17-19 highway
I just got my 2004 5.3L Tahoe Z71 less than two months ago.
I am really pleased the Tahoe does noticeably better than the 4.0L 05 Jeep TJ Rubicon with 33x12.5 tires I used to have.
Granted, the Tahoe now only has 245/75 R16 pizza cutter tires on...
I swapped (they were free/even Steven exchange) over to some stock Silverado 16 inch alloy rims, so I could have more choices at cheaper prices than 20 inch rims that it came with from the PO.
I am fine with the tiny, skinny 245's for this season. The fat tires I had on the Jeep were not fun in winter driving or hitting deep puddles on the highway; and the mileage was about 12.5 on a good day with a tail wind.
My MPG might drop a little, when I switch over to 265/75 R16 in the spring. But, I don't thing the mileage will suffer too much with that upgrade.
For the size, weight and power of the Tahoe... I am impressed it does as well as it does on a tank of gas. VERY happy coming from the Jeep to Tahoe world!
jwth
Michigan
2003 Yukon 5.3 Flex Fuel running 87 octane regular
24 plus highway and 19 to 20 City
Custom Tune
rockola1971
Indiana (formerly IL)
Bone Stock 2003 245k on the clock. 14-15 city and 19-21 on the highway depending on wind direction and which highway/interstate (speed limits vary). I 99% of the time run 87 octane.
Mudsport96
I know it is not a Tahoe, but it has the same drivetrain from the trans back as my Tahoe (L33 instead of L59) but the Silverado has 17.1 total lifetime mpg average. Father in law never reset mileage in 400k lol. Ok hijack over.
Conedaddy
