Slow fuel fillup
Matt06Yukon
Hey, I picked up a super clean 2007 Escalade about a month ago. Besides fixing all the little body imperfections (door handle, dash crack, folding mirrors)
it does also have an issue with slow fuel fillups. Now I know this is common with all of GM's trucks, I'm not getting any codes and everything looks good underneath. Where should I start first you think? Change the Evap module near the tank?
Thanks
Indicative of a vent blockage, whether that's the canister vent valve back by the tank, or the canister itself, or evap lines are plugged with charcoal pellets from the canister. First thing I'd do is see if the canister vent valve is working properly. With no voltage applied (as in key off or connector pulled) you should be able to blow air through it. Applying 12v to it should close it. Repeat in succession to eliminate an intermittent valve. It may have a remote air filter so be sure to check that, too.
Like @Bill 1960 said, there are more than a few threads and YouTubes on troubleshooting.
wsteele
Thanks
Beauty, congratulations.
Matt06Yukon
Matt06Yukon
It really is, I love the color. I have a 2005 Sierra in that same paint code that I use for an all season vehicle and I fell in love with the color. To find a rust free Esky in that color was real luck.
Thanks
If you can reach it, pop off the large hose going to the EVAP ("charcoal") canister and see if that fixes it. Did it have the fuel pump replaced before you bought it? There are fools that forget to route the main vent hose over the cross member right before raising the tank all the way into position. It gets pinched and flattened between the tank and crossmember and is completely sealed/blocked.
If unplugging it from the canister fixes it, then you know the problem is in the canister.
Matt06Yukon
Matt06Yukon
Thank you, no I don't think so but the tech at the dealership wanted to drop the tank to "fix it" before I bought it. I told the salesman not to, I'd rather figure it out myself than have someone eff it up more. I'll check those lines, everything looked pretty factory when I crawled underneath there. At least working on it will be easy without any rust.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Thanks
Nice truck, nice garage! Have you sealed that concrete floor yet?
You can see the hose and cross member through the left rear wheel well. I thought I posted a pic a while back but can't find it. I might've dreamt it.
You rock!
Damn- I posted incriminating pics AND a confession! Hey @Matt06Yukon, this is what happens when you don't pay attention. There's not much slack in that vent hose, so you have to get the tank close to the cross member it rests against, then route that hose over it and continue lifting the tank into place. Don't forget to disconnect it before dropping the tank, either.
You can get an idea from the pic of where to look from the wheel well to see if it's pinched. If not, disconnect the tube from the EVAP canister to isolate the problem to that or the tank.
Thanks for finding that, Steve. :happy160:
I'm kinda tuned in to evap issues, since I went through a *few* on my NBS, so I was paying attention when you posted your saga. I'm glad my lines don't have to run over any crossmembers!
Matt06Yukon
Matt06Yukon
Interesting. Ok, Thanks man, I'll definitely have to take a closer look. Its getting cold around here and the truck is gonna be hibernating for the winter. I should have plenty of time to check it out.
CKendrick
