2004 6.0 NV4500 Tahoe
pwtr02ss
Tennessee
I got the radiator in and oil cooler lines hooked up. Also changed the oil with nothing of concern to note in the filter or on the plug.
Really pleased with this ColdCase so far the welds look great and in addition to the oil cooler it has a trans cooler built in. For now the trans cooler will be capped off but in the future it might become the power steering cooler.
On initial startup it needed a 7th quart of oil to show full on the dipstick and at least an extra gallon of dexcool to fill the cooling system. I also noticed on initial startup oil pressure took a good 30seconds to get above 20psi which is probably due to filling the cooler and lines.
Radiator is nice!
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Radiator is nice!
I’m happy with it, it survived an hour tow trip so far. Had the trailer loaded a little over tongue heavy which made the steering funky but not too bad.
Laid some decent welds down in a core support on a buddies wrecked car.
pwtr02ss
Tennessee
Hey man, with that stance, you may attract some fellow Florida dudes. You're a 4" lift in the front away from being in the bro stance
Nice looking welds too, btw
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Lmao it was pretty bad I loaded it in my pasture which is kinda hilly so I didn’t notice it at first but as soon as I got rolling I could feel the steering floating a bit, honestly not to a dangerous level but not as good as it normal feels when towing proper. I think I need to look at a raised ball before Randy tries to go down my rabbit hole:oops:.
Funny thing is the rear wasn’t really compressing because I had 25* in the bags it was just lifting the front. If I hadn’t had the bags I would have had to relevel the load and push it back enough that the ramps would have had to be removed which is a PITA.
I haven’t noticed any issues with coolant not heating enough although the gauge still only gets to 175ish. Also it doesn’t look like I’m losing any OP with the cooler like I had read about. I think I had seen an average of a 5-10psI drop when adding a cooler which is pretty significant imo.
Lastly I didn’t get to tow for long but I did stick it in OD for 15 miles or so and managed 11mpg on the DIC readout and trans temp never reached 150. Overall today was a massive win win!
...I think I need to look at a raised ball...
This one line reminded me of an awesome joke I heard in a movie decades ago:
A guy is walking through Mexico...​
When he comes up on a Mexican man taking a siesta with his donkey tied next to him. "Excuse me," the man says "Do you know the time?"
The Mexican man looks up sleepily, grabs his donkey by the balls, and slowly raises them up as if weighing them. "Eet's about one turty."
Confused, but in a rush, the man thanks him and goes on his way.
Later in the day, the man is returning on the same route and sees the same Mexican in the same spot with the donkey still tied up.
"Excuse me," he says, "Do you know the time?"
Again, the Mexican grabs his donkey by the balls, raises them up and says "Eet's seex feefteen."
"Okay... okay. How can you tell the time that way?" The stranger asks in bewilderment.
Once more the Mexican grabs the donkey's balls, lifts them up, points and says "You see that clocktower way over there?"
1,000 internetz to anyone that knows the movie.
pwtr02ss
Tennessee
I've seen the GIF. As a matter of fact, the owner of the company I work for sent it to me about a month or two ago. I can't say that I've ever seen the movie though lol
Not that one! But, you already know through our texts.
Hint for anyone else that might be wondering: You might be high, or want to be if you were watching the particular movie in question.
pwtr02ss
Tennessee
I won't claim my internet points this time...lol
It’s Cheech and Chong but don’t know the movie, Up In Smoke?
Damn P0128 done got my asss, coolant isn’t getting above 150* so I need to go get a TPMS sensor and make a restrictor this week. I guess because the first trip I was towing and it was 70* it got warm enough not to trip that code but today during short runs around town it finally popped on
You could temporarily use something like a couple of steel straps with two bolts or cable ties to squish it a little or a lot. As a sort of MacGyver test.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I think I'll put a hose clamp on it and tighten it down a bunch until I get time this weekend to cut the TPMS sensor up and install that.
Tonight I'm starting aluminum Tig welding and I want to get right to stuff I care about since I just spent 14 miserable weeks on stick welding so, I just ordered 3' of 4" OD .070 wall tubing to cut into pie cuts and make an intake tube for the Tahoe. Although my CAI tube is just fine it has a notch cut into it where it is designed to clear the factory clutch fan shroud. The notch is ugly and looks to me that it could Plausably restrict a little flow, probably not enough to lose power but like I said it's ugly. I think a pie cut intake tube polished up all purty and made by me would be sweet.
If anyone has a lead on a good program to get the pie cut measurements that would be sweet to find. Also I've never tried to polish bare aluminum to a high shine finish, if anyone has a list of supplies I need and a technique to use I'm all ears!
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Scored a nice win tonight against the 2018ish C300 Benz that I have been trying to line up against for a few months now. In his typical D bag fashion he was weaving through traffic behind me only to get caught at the same light I did. He was obviously eager to blast past me when the light turned green because he was inching forward every second or so nosing far past the stop line. With his windows down and vape firmly in his grasp the lights turned green and I first gear treed his ass good with a quick clutch slip then throttle stab! The Tahoe leaped out in front and although He tried to catch up I luckily got clean 6,800rpm shifts and the gap widened up to about 3 car lengths. At 90ish I let out and give him the chopped fingers and he slowed down enough that I made the next light and he didn’t.
I’m hoping he returns for more and I can pull off the same win back to back. It’s difficult to muscle this thang into gear but if it clicks and sticks it’s a blast!
Ossipeelake
