New Owner of 2003 yukon denali, with 307000 kms
2003LQ4Denali
Hi I'm looking for advice on what I should be doing do this yukon to bring its maintenance back up to date, I purchased this yukon a year ago finally getting the funds about 6 months ago to start working on it and getting it drivable, I had the transmission swapped with a rebuilt one on Sept 9th 2021, the shop just found out my check engine light is not working ( this was working before ) so after I received the truck with the transmission I drove it and did not know the vehicle was sending codes, it drove fine but the shop found out it was only using 2nd gear and 3rd gear, the guy I bought the transmission from says it could be the solenoid or an electrical issue somewhere else and the shop also found that my starter solenoid is starting to get stuck and not disengage, my wheel bearing sensor might be faulty (causing traction active to come on), my belt and fan clutch are old, which was causing a grinding type squeal
GMT800 2005 Tahoe Z71
Navy Supporting Member
Welcome to the forum and beside dealing with codes and what goes with all that, if you do not know the age of the rest of the fluids, change them all, at the minimum.
2003LQ4Denali
2003LQ4Denali
Okay I've changed the oil and the transmission was changed as well, so that leaves the power steering, brake fluid and coolant, am I missing anything?
Differentials and transfer case. Almost forgot, the blinker fluid too.
Check that washer fluid for this time of year.
2003LQ4Denali
2003LQ4Denali
Knew I was forgetting something hahaha the washer fluid was just refilled by the shop also so it should be good
Welcome to the Forum from NH.
Pics of the truck, please.
2003LQ4Denali
2003LQ4Denali
Thank you very much for the welcoming, I plan to participate and learn as much as I can from everyone, I'm very interested in these trucks I always wanted one and now I finally have one and everyone has some interesting and unique ideas here, I think I'm only going to read a couple of posts on the thread but then I'm reading the whole thing because it's so interesting what everyone has to say haha
2003LQ4Denali
2003LQ4Denali
Yes I do agree with you, the seats are so comfortable even in decent condition, can't wait to rebuild the seats to like new condition but it's been sitting since I found out a couple days ago my check engine light is not working and I have a p0753 but it drives fine, I was told it's only using 2nd and 3rd gear, but I don't want to risk ruining the transmission I put in it.
These rigs are known for ground problems. I would check all of them before thinking there is a problem with the trans.
2003LQ4Denali
2003LQ4Denali
Yes I heard of that, do you think this would cause my starter to continue trying to start once off and key is out, or is it just the solenoid starting to stick and and starter should be replaced? one of my next upgrades is the ground wiring, I keep seeing stuff about the big 3 or sometimes the big 4, I joined this forum to help educate myself about all the possible upgrades or even stuff that could be replaced while I'm about to replace other stuff, as I did my ball joints and tierods I saw that there could've been other parts replaced while I was there haha
Do a search of the threads here about the Big 3. Lots of them and read thru them. The ground problems can cause so many things. Some of the stories here make you think aliens have taken over your rig. The starter still trying to engage with key off and out may be a starter relay in the fuse box under the hood. The cover will identify the location and you can see if there is another relay that is a match and swap it out and see if that fixes the problem. The starter is getting power feed somewhere for that to happen, with key off and out. If the starter drive is sticking that will damage it and will shorten the life of the starter. I would do the obvious known problems/weak spots first of the grounds and see what happens.
PNWYukon
Olympia, WA
I saw that plug hanging out of the grill. You must live somewhere very cold. If in the rust belt, then all grounds are essential to check and reseat.
As for the code for the 1-2 shift solenoid. They fail occasionally, so it could be that easy and they are not expensive. I want to say that you can even change that solenoid without removing the valve body, but someone will correct me if that's not true.
If you are refreshing it anyway, you should be doing transmission fluid, filter and possibly something like the TransGo shift kit for the valve body. That will replace old springs and improve shifting.
I would inspect the separator plate as well while in there, these are known for the check balls punching their way through the plate. On mine it was the check ball for 1-2 upshift was almost pushed through causing erratic shifting.
2003LQ4Denali
2003LQ4Denali
Yes it happens sometimes when the vehicle is started then seems like everything is out of wack turn it off and the starter is still trying to start if the key is left in on "on" it has a chance of starting itself which it has just a couple of times but I will study the big 3 threads for sure
Okay this evening my neighbour said he was walking his dog this morning and it was trying to start but I woke up late and did not even go outside yet to do anything with the yukon around the time he said and also mention the previous owner was pulling the starter fuse alot to prevent use of vehicle
Yes I live in Canada haha very cold, but I bought a rebuilt 4l65e with a corvette servo, accumulator work, hardened sunshell, a rebuilt torque converter so since my engine light wasn't working I didn't know my transmission was sending a code till I took it in for an alignment and asked some questions.
I contacted the person I bought the transmission from he is very sure it's not his transmission that is causing the problems but I'm hoping it's only the solenoid or the harness if he didn't put a brand new one in, I would expect what you suggested would be the case if the vehicle had it's original transmission, the original was toast from previous owner
2003LQ4Denali
2003LQ4Denali
Could these areas be causing problems, they look pretty rough
PNWYukon
Olympia, WA
Hope you got a warranty from the transmission person. Going that deep into a transmissions rebuild, you would think valve body solenoids would have been replaced along with all the other springs, o-rings, seals.
"he is very sure it's not his transmission that is causing the problems",
Said every mechanic ever. No matter what he said the transmission is throwing codes and not shifting, that's a huge problem.
2003LQ4Denali
2003LQ4Denali
He is going to help me resolve the issue, he is sending me a solenoid first so I don't have to pull the transmission already, I'm just hoping he thought the solenoid was good enough but then stopped working, he said another transmission he sent for someone's Hummer had an electrical problem at the ignition and the transmission wasn't getting enough power and it went into limp mode and they fried it twice until they found that out but my shop said I have 2nd and 3rd gear, my temperatures were normal when i was driving around, just when I come to stops I'm starting in 2nd and my electrical problem seems to have my yukon trying to start itself
wwiizz
