Sam Harris
It rained Tuesday, so she got another wash and half a detail today:
If a bearing spins, it just rotates and blocks the oil passage resulting in loss of pressure i believe. Somebody that has encountered one will hopefully chime in. @Tonyrodz didnt your hoe have a spun cam bearing?
Yup, that's how my 1st 6.0 died. It sounded more like it had a lifter tick, no low knocks or anything else telling. It spun a cam bearing. We didn't know what it was until it was taken apart. I really hope that isn't your iissue.
Teamiez
Got the Tahoe sprayed for the rust proofing yesterday just in time for the first salting of the roads in NY this morning. Also was very close to smashing the guard rails on a over pass at 230 am on the way to work this morning before the salting. That damn black ice snuck up while half asleep!
Damn! You guys are salting already?!
I am not sure if they did the main roads / thruways later in the am, but the campus I work at had the salters all over already. Probably a pre caution as a lot of people on this campus don’t know how to drive on a dry summer day hah!
It’s still 45-50 in the mornings here in Oregon. We did have a few mornings of 40 a couple weeks ago. But they never salt here regardless. And we have terrible winter drivers that get stuck in an inch of snow lol.
ScottyBoy
Shreveport, La
Well shiiiiit. I DO have a lifter tick. But I've had a lifter tick for YEARS. Probably since around 2007 or 2008. But it only ticks for a minute or two right at startup. Once the engine warms up a bit, it stops ticking. I've talked to several mechanics about it over the years and they all told me the same thing. They said unless it ever gets worse, then don't even worry about it. So I haven't worried about it.
BUT: After replacing the oil pump, the lifter tick was VERY loud on the initial startup. Sounded almost like a slight knock it was so loud. It did that for about a minute to a minute and a half, then stopped. Now I don't even hear any ticking at at all.
Probably once the new pump circulated the oil through the galleries it stopped. New pump sounds like it's doing its job. Did you do the Melling hv? That's what I used in the Tahoe and Express van.
But you still have almost no oil pressure at idle? Using a mechanical gauge?
NoReverseYukon
NE Wisconsin
My "rust-proofing" consists of spraying the underside with a 50/50 mix of diesel fuel and chainsaw oil. I'll be doing that w/i the next couple weeks to all 3 of my vehicles.
Teamiez
Everyone has there own ways that seem to work I heard of ‘used motor oil’ as well. Whatever this place uses it certainly works and they don’t go light.
hertahoe
Washington
Just replaced the transfer case motor in under 45 minutes! Last one took way too long. This time I took out the drive shaft. But I did notice the transfer case leaking. Probably have to shop to have them look at it. Next is the body bushings and rear sway bar issue.
What's up with your rear sway bar?
ScottyBoy
Shreveport, La
Yes, at idle ( 800-900 RPM's) it's under 10psi unless I press the gas pedal to get it up to at 1500-1800 RPMs, then it will sit at a out 20psi at that engine speed. And the mechanical gauge reads nearly the same as the dash guage. It's a cheap Harbor Freight guage if that matters.....
This morning I started the engine and with the cold oil (it was about 45 degrees outside) it idled at about 20psi. The lifter did the normal tick for about 20-30 seconds, then got so quiet I couldn't hear it. And when I say "normal", I mean the same sound it's been making on startup for the last 13 years, not the loud noise it made after the first startup after replacing the oil pump. So I let it idle at 20psi for about 3-5 minutes and let the engine warm up. After it warmed up, the oil psi dropped down to just below 10psi, probably about 8psi.
Maybe try a little thicker oil?
ScottyBoy
Shreveport, La
Yes I installed Melling HV pump. Thinking about running a bottle of engine flush before I drop the oil pan again. My thinking is that will hopefully clear any more sludge from the oil passages that I couldn't manually clean like I cleaned the pan and timing cover. Then change the oil yet again, and clean any crud or sludge off the pickup tube screen ( if any gets on there). Then if I still have low pressure after that, maybe try a bottle of Lucas oil additive. If that works, I'll just drive it with Lucas added at every oil change, and starts saving up for a new engine.
NjA4207
