Rear axle (wheel) bearing question
EddieC
Should there be any perceivable movement of the outer hub ends of rear axles on our '08 Tahoe?
I am trying to isolate a rear area grinding noise and found the right rear axle can be moved both in and out enough to see and hear, as best as I can measure about 35 thousandths. Without even removing the wheel, in and out movement can be induced. I also more grumble from that wheel compared to the other side.
I had thought my noise was the differential but now this axle movement throws a question on the outer wheel bearing.
We're at almost 100,000 miles and both front hubs/bearings went bad so I hoping the same for the rear.
exp500
In an out great, up n down no good. .035 ok too. Check the brakes on rt. side. Remove caliper to properly test bearings, so brakes dont stop your wobble feel. Grinding no good.
I would check carrier/pinion bearings too.
Geotrash
Dave
Richmond, VA
EddieC
EddieC
Dave, no leaks and differential fluid level is good. It just seems odd that I can grab the tire and cause clunks when pushing and pulling.
Brakes are ok and fairly new pads. Caliper is floating as expected.
I hear grinding (in the rear) going down the road but not obvious on the jack stands rotating tires by hand. Not comfortable doing it but spinning the tires with the engine while on the stands seems to have more noise on the questioned side than the other and it could be perceived as grinding. That procedure is a bit tentative though because the locker clonks in and for some reason the speed increases and then there's too much drama and noise to tell anything.
I will pull the caliper and wiggle the axle some more. I thought I felt a very slight up and down movement but maybe that was wishful thinking.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Agree with @exp500 and @Geotrash on the inspection process. That in and out play is normal. You don't want any up and down play. If do pull the axle for inspection, that is the perfect time to go ahead and do the bearings and seals and make sure to inspect the axle surface where the bearing rides. Pitted or galled, not good.
Geotrash
Dave
Richmond, VA
I also agree with @PNW VietVet and @exp500 that clunks when pushing and pulling are 100% normal. The fact it’s not leaking is also a good sign. Let us know if anything changes with the caliper off.
Capybarbro
