I need mirror HELP!
BoatsAndHoes
So Ive been running some aftermarket tow mirrors for about a month now and overall I am very pleased with them, however I’m having 1 slightly annoying issue with them. My Tahoe has the memory feature for the mirrors and since the range of motion and motor speeds are different on the new mirrors, sometimes when I get in the truck the mirrors are pointed all out of wack. This is causing me to have to adjust my mirrors almost every time I get in.
QUESTION: does anyone know how I can disable ONLY the memory setting feature for the mirrors?
B
BoatsAndHoes
Youshould have 2 memory positions...
I’m well aware of that. I’ve programmed both of the memory settings to the same position. I’m not looking for condescending answers, I just want to know how to disable the feature if at all possible.
B
BoatsAndHoes
This is the 2021 forum; post up your model year and consider putting your make, model, and year in your signature.
Thank you for the advice, I didn’t realize I had posted in the wrong area. Is there a way to move or remove the post?
CaptainAmerica1
Arlington TX
He wasn’t being condescending. You mistook the tone of his response.
CaptainAmerica1
Arlington TX
Can’t you just disable it from the dic? Or with a tech2? It may require bcm programming.. if I had the feature I could try to disable it but sadly mine is super basic model…
Walchit
Sometimes text can be taken the wrong way. I know my lumbar always resets back even though I changed both settings to be deflated. It's kind of annoying, but the mirrors would be worse. I wanna get a set of tow mirrors, did you get the cheaper Amazon ones?
unless someone is adjusting the mirrors or pressing a memory button they should not move. PERIOD
so that being said there must be some other reason, maybe the door mirror switch is bad or funky or the mirrors have some internal problem.
possible fixes: test or replace door mirror switch
or pull a fuse #14 inside driver side panel
varminpoolteam
