CMoore711
@Slow5.0 Good for you for testing the actual before and after difference of your Wilwood BBK brake upgrade. Dropping down to 90 ft. from 130 ft. from 60-0 mph is a notable improvement over the stock brakes!
Everything is so pretty out of the box and upon initial install. Wait until you have 50K+ miles on them! One thing I wish I did was powder coat the rotor hats before installing mine. The factory coating black "e-coating" on the rotor hats is significantly better than what you find on other aftermarket rotors from the likes of R1 etc., but after a while they will still start to show some corrosion.
Curious what made you choose the 16" TC6R kit over the 16" TX6R kit for up front?
Slow5.0
Missouri
I just like drilled and slotted rotors, yeah TC6R have 2nd and 3rd piston smaller than TX6R 1.38 vs 1.62" or piston area 5.40 vs 6.52 in². also TX6R are for heavy loads like pulling trailer and i dont plan pulling much. Also TC6R comes with BP-10 pads, TX6R comes with BP-20. Those BP-20 will create much more brake dust. I could mix and mach parts but will cost a lot more buying that way. Plus i got good deal on autoplicity, $3900 shipped
My front hats are aluminum, rear are steel, are you talkin about rotors and rust on them ?
Also you said wait till 50k+ miles ??
CMoore711
I believe both drilled and slotted rotors or just slotted are available for both the TC6R and TX6R 16" brake kits. They consist of the same rotors and rotor hats, the only difference being the calipers and pads.
My front hats are aluminum as well, with my rear hats also being steel. We have the same brakes; Only difference is my front calipers are the TX6R w/ BP-20 pads vs. your TC6R with BP-10 pads.
I had only brought up 50K+ miles because that is what's on my set-up so far. My front aluminum hats still look pretty decent, but the rear steel ones display some corrosion/rust. Which is to be expected on any brake set up really.
Slow5.0
Missouri
Only thing i notice NA 6.2 doesnt have enough power anymore to overcome rear Wilwoods with power brake, i guess its time for boost
Is there way to install line lock ? I bet BCM will go crazy
RST Dana
OH
Washed this for my weekend adventures.
Slow5.0
Missouri
Tonkatoy hows fittment on Morimoto headlights, are they plug and play ?
I talked with TRS and asked them about those heqdlights on Denali since i Denali have D3S HID low beams vs H11 on SLE/SLT but he couldnt answer my question. So does Morimoto headlights comes with extra harness for H11 and D3S or whats deal
Tonkatoy
Yes plug and play, other then the tap wire in the fuse box, sharp looking lights.
Ghost10
Just got her washed and vacuumed
She was looking like a $2.00 hoe for a hot minute
Bigkevschopshop
Northside H-Town
Road tripped last Saturday to New Braunfuels Tx and back to pickup a Model A motor...
80 MPH average... Fuel Mileage was better than expected... Good 1st road trip all in all with it...
Cargo that was shoved in the back....
I can tell that there is alot less room height wise in the cargo area due to the floor from the NNBS trucks... But the under floor storage is nice for trailer hitch and straps etc...
Slow5.0
Missouri
These days GM offers black out editions, wish they started that long time ago, lots people like denali and ltz interior options but dont like too much chrome outside. Im same way, i like SS and chrome on my semi truck but not on my cars. I remember back in Bosnia back in early 90s i had E30 M3, 1st thing i did was painted black chrome strip around windshield and windows, black is nice with everything on anything
pwtr02ss
Tennessee
Tested 60-0 mph. 130ft before and 90ft after on bald OEM Bridgestones tires
Very nice! The stock brakes are lacking, especially with the 22s. What did the kit set you back? I'll be doing the brakes on my Yukon in the next 10-15k probably.
EDIT: Disregard, I didn't read far enough. That's not terrible for peace of mind!
Jeff_
Scottsdale, AZ & N. Idaho
Today I finally did the thermostat flip for the 6L80 today.
Hoping to see a noticeable drop in trans fluid temp after this.
Going to do a long 3000 mile drive soon pulling my Camaro on a trailer, so this should be helpful.
Only pic I snapped - you can see the thermostat plunger and spring at the top. Cleaned the housing up a bit and threw it back on. Was a 15 minute process.
Also pumped out and replaced a gallon of transmission fluid while I was at it.
And then changed the motor oil and filter.
EDIT: Initially I had just removed the plunger and spring completely, but upon further reading from other members on this forum I opened it back up and put the plunger back in, just FLIPPED.
AdrienR
