Calling any 6l80e experts
Clg88
New to the forum
I have a question about 6l80e repair & improvement.
I have a new to me 09 Yukon XL. The 6l80e is in pieces on my bench for a rebuild, and I will install a valve body kit at the same time.
I'm wondering if anyone has experience building or modifying these transmissions who could weigh in.
I am looking at both the Sonnax Zip Kit and the Transgo Shift Kit.
Is one preferred over the other & why?
Thanks
Foggy
KS
I was going to do just the zip kit and a new aftermarket torque converter... but
then I decided to add a supercharger, so I went with the cirlce D stage 4 kit with all the
upgraded hard parts...
I think for regular use, the zip kit and a new TC is the way to go.. Remember, the OE
torque conv has a real crappy lock up clutch in it.. Go aftermarket HD that will have
a decent clutch in it or you'll be back into it real soon
Geotrash
Dave
Richmond, VA
Transgo usually has a few bits to fix specific weak points that sonnax doesn’t include in their kits, but not sure about their stuff for the 6L80. When I rebuilt a ZF 5HP24 on my bench a few years ago, I bought a complete master banner kit from I forget who, plus a few bits from Sonnax and a few bits from Transgo to get the perfect setup.
New to the forum
Thanks
Dorman TECHMs, at least a few years ago, had a very high faulty rate. Stick with GM OE if replacing the whole thing. Alternatively, you can rebuild it on your kitchen table with this kit:
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving recommendations and perspectives from the knowledgeable folks on this Forum.
Just Fishing
Can't fix stupid
Utah
Read through the documentation on the 6l80e on the sonnax website.
Lots of information about fixes, known issues, etc.
I did a mix of Sonnax and Transgo on my valve body when i first got the hoe.
Get the ac delco screen kit, sonnax valve body check balls (they don't shrink like the oem).
And i added the sonnax endplug kit for good measure.
I also rebuilt my techm, i found the pressure switches were on their way out.
Sonnax has a tool that was very helpful.
The transgo shiftkit also had spare laminates and seals, it was a little bit of trial and error and found the spare set to be very handy... lol
Charlie207
LFOD, New Hampshire
Just Fishing
Can't fix stupid
Utah
One of my favorite new subscriptions. The guy knows his stuff.
My only wish is to see him dig into a Nissan RE5R05A (Armada/Titan) and see how it compares to a 4L60 or 6L80. My Armada is a stock 2005, and it shifted better than my 2014 Yukon 6L80, even after the Blackbear tune.
I wish he went into detail about what he does for "Fixes" and assembly.
Seemed like people had to pry information out of him for a simple thing like a pwm block off in the 4l60. :jester:
but the disassembly videos are very interesting.
It's also nice to see what types of tools he uses, especially when it's a custom tool.
Just Fishing
Can't fix stupid
Utah
That's the tool!
and that price is terrible, but it seems to be the going rate right now... weird.
I paid about $40 for mine
(I don't know what the difference is, but this is the one i used for my 6l80)
Sonnax also has a kit to replace the laminates and seals.
At a minimum, make sure you have an extra set on hand.
For me; those laminates seem to have a learning curve. :jester:
I had a sec and found some parts,
(I should probably add it to my build thread for safe keeping... lol)
GM Genuine Parts 24245720 Automatic Transmission Control Valve Body Spacer Plate with Gaskets
ACDelco GM Original Equipment 24236934 Automatic Transmission Control Valve Solenoid Filter Plate Kit
Important as it also comes with the needed seals.
Sonnax tool - 124740TL30 - 6L45 6L50 6L80 6L90 6T70
also search for "124740-30K" finds it with prime
Transgo SK6L80 Shift Kit
This goes with the above kit (mentions the pn in the shift kit instructions)
Transgo 6L8CSTCC Valve Kit
Missing are the sonnax check balls, out of time to find the pn for ya.
And a bunch of this i bought locally from trans star, so i don't have it in my order history.
The pan gasket should be reusable, and it's like $20 if you need to replace it.
I didn't but i have a spare on hand.
Filter kit,
GM Genuine Parts 24236933 Automatic Transmission Fluid Filter Kit with Seal
Geotrash
Dave
Richmond, VA
That's the tool!
Filter kit,
Thanks for sharing this info. Bookmarked for when the time comes for me.
schafer98
